P0A93 is that ok to drive
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by BlackBeauty 09, Sep 7, 2019.
  1. BlackBeauty 09
    BlackBeauty 09 Junior Member
    17
    beaverton, oregon
    I have a 2009 with 134k miles on it. just serviced last week. On Friday the dashboard went tilt!!! I took it to the Beaverton Toyota dealership. They found the P0A93 code fuel pump/inverter needs to be replaced. They charged me $126 for that. I will not be going there again except for car washes.
    My questions are:
    Is it safe to drive?
    What is a reasonable price to pay?
    What would be the signs of a water pump inverter needing to be replaced? My car sits a lot and I haven't seen any pools under my care.
  2. JC91006
    16,933
    8,643
    They should be able to fix it for around $500.
  3. richmke
    richmke Member
    73
    48
    Milwaukee, WI
    Yes. The problem is when it refuses to move. It could happen at any time.
    It is not a leak. It is a failure of the pump to move water. The inverter will overheat, and the car will shut down to avoid overheating the inverter. When the inverter cools down, you can drive a few more miles.
  4. BlackBeauty 09
    17
    beaverton, oregon
    Thank you both. I went back and looked at my records. I had the water pump replaced in Jan 2018. Does it make sense that I need another one? I have put on 11K miles since then
  5. bisco
    52,782
    inverter water pump or engine?
  6. dolj
    dolj Senior Member
    8,633
    4,387
    Wellington, New Zealand
    The P0A93 code. You could also put the car in IG-ON (two presses of the Start Button with your foot OFF the brake) and then take the cap off the inverter coolant reservoir. Peer in and see if there is any turbulence in the coolant. If no turbulence, there is your confirmation.
    That is most likely a different water pump, the one for the ICE.
    #6 dolj, Sep 8, 2019
    fotomoto likes this.
  7. BlackBeauty 09
    17
    beaverton, oregon
    Tech notes say "r/r water pump and gasket and drive belt and belt tensioner pulley bled the cooling system
    Noise quieter but still present after water pump repair. will need to replace tensioner pulley.
  8. BlackBeauty 09
    17
    beaverton, oregon
  9. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,526
    Bay Area, California
    2019 Prius Prime
    These are 2 different water pumps ;).
    The note you are referencing is for the engine, and the code is for the inverter water pump:cool:.
    Hope that helps (y).
    Skibob, BlackBeauty 09 and dolj like this.
  10. BlackBeauty 09
    17
    beaverton, oregon
    Inverter pump
  11. dolj
    dolj Senior Member
    8,633
    4,387
    No, actually, the ...
    This refers the gasoline engine's water pump (which is mechanical) and is different to the inverter water pump (which is electric). You need to beware that your car has more than one water pump as has already been pointed out in this thread. In fact it has four, and these pumps we are discussing are two of them.
    #11 dolj, Sep 8, 2019
    Abdu_mka likes this.
  12. BlackBeauty 09
    17
    beaverton, oregon
    Doji,
    I don't know/understand that my car has 4 water pumps.. I don't know much about my car which is why I am on here trying to get information. The way your response was written was insulting. If you want to help then restate your answer. Otherwise just don't read my thread.
  13. JC91006
    16,933
    8,643
    Your car has more than 1 water pump, the failure code points to the inverter pump. You don't have to concentrate on anything else that's provided in this thread.....just the failure points to the inverter pump
  14. dolj
    dolj Senior Member
    8,633
    4,387
    I apologise if you found my response insulting, it wasn't meant to be. I reread it and have re-worded the last two sentences. Other than that, I'm not sure how I can be more objective.
    In any case, I feel like your questions have been answered satisfactorily. If you need any further clarification, perhaps your could ask further questions seeking clarification.
    #14 dolj, Sep 9, 2019
  15. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    JC91006 likes this.
