P0A94 code DC to DC converter
Discussion in 'Gen 2 Prius Technical Discussion' started by john elliott, Jul 22, 2022.
  1. dolj
    dolj Senior Member
    8,652
    4,404
    Wellington, New Zealand
    That is where a leak can occur when that happens. It usually drips from there behind the inverter and to the floor.
    There is also an overflow drain at the rear of the inverter reservoir that follows a similar path. This would only overflow if the reservoir was overfilled.
  2. john elliott
    john elliott Junior Member
    washington
    After replacing the reservoir and the o ring I appear to be back on the road. Thanks again for the help.
    SFO and dolj like this.
