P0A94 code goes into limp mode and no flow in inverter reservoir. Just swapped inverter.
Discussion in 'Gen 3 Prius Technical Discussion' started by Jeremypeck0719, Jan 16, 2023.
  1. Jeremypeck0719
    Jeremypeck0719 New Member
    Gustine Ca.
    Just swapped inverter after getting all lights lit up on dash, and throwing a P0A94 code. Car has been driving fine after a couple miles. Even getting 600 miles to the tank instead of 400. Now all of a sudden same thing happened again. Lights lit up on dash including triangle and went into limp mode. Had it towed to my house. And it had check engine light on. Put scanner on and had no codes, just in monitor it had a P0A94. Cleared check engine light with scanner and all lights went off and now drives perfectly normal. Its driving me crazy! I dont see flow in inverter reservoir. But feeling hose and listening to pump it seems to be working! Let me know what ypu think thanks
    51,104
    Where did you buy the pump?
  3. ASRDogman
    ASRDogman Senior Member
    7,199
    3,766
    You may be hearing the pump, but you don't see the water flowing. I don't think the
    pump is working. They about $120, worth changing...
    Jeremypeck0719 likes this.
  4. Jeremypeck0719
    Gustine Ca.
    Never put a new pump just new inverter
  5. Jeremypeck0719
    Gustine Ca.
    I will order new pump and replace it, thanks
    Im thinking it was never the inverter it was the coolant pump.
  6. ASRDogman
    7,199
    3,766
    It's such a pain to replace the pump, you basically have to remove the inverter
    to get to it, so it's best to replace it while the inverter is out.
    It's better to do a diagnoises before replacing parts.. (y)
    Hope the new pump resolves the problem.
  7. bisco
    51,104
    get an oem from the dealer, a lot of black market pumps out there
  8. Jeremypeck0719
    Gustine Ca.
    Ya i replaced pump drove it a couple hundred miles now a P0C73 just came up on my wifes commute to work! Cant win with this car!
  9. bisco
    51,104
    oem from dealer? if so, maybe it's a wire/connector problem
  10. Jeremypeck0719
    Gustine Ca.
    No online.... not an oem. When i installed it after draining entire system and bleed it out with putting in ready mode. pump turned on and filled system and i did it like 3 times until sytem was full. Drove it a couple hundred miles and now this code comes up! P0C73..
  11. Jeremypeck0719
    Gustine Ca.
    You think the new pump already failed?
  12. bisco
    51,104
    there have been a lot of reports here of black market chinese junk that fails quickly.
    any movement in the reservoir?
  13. Jeremypeck0719
    Gustine Ca.
    Dont see any now! Just code P0C73 keeps coming up! I guess i will replace pump again?
    Best place to buy an OEM? No dealer near me!
  14. Mendel Leisk
    40,555
  15. Jeremypeck0719
    Gustine Ca.
  16. bisco
    51,104
    You’ll have to go online to camelback Toyota or other
  17. Jeremypeck0719
    Gustine Ca.
    Ya i see slight movement inside reservoir when in ready mode. Maybe trapped air bubbles? I also hear pump....
  18. Jeremypeck0719
    Gustine Ca.
    Black market pump is no good! Ordered oem pump just now will receive it Sunday!
    ASRDogman likes this.
  19. bisco
    51,104
    all the best!
