1. Thumb
    Thumb Junior Member
    Greece
    Hello
    This code appear after I connect two Prius batteries in parallel.
    Any idea??
  2. S Keith
    S Keith Senior Member
    799
    329
    AZ
    2003 Prius
    What does the repair manual say?
    What were the sub codes?
  3. Thumb
    Thumb Junior Member
    Greece
    Repair manual says that is inverter overheat.....but this code appear 200meters after I connect the two batteries
  4. S Keith
    799
    329
    AZ
    2003 Prius
    No it doesn't. It has 25 different subcodes associated with it. What are the subcodes?
  5. Thumb
    Thumb Junior Member
    Greece
    The only code that I read in HV System is P0A94 ,in HV battery has no DTC.
    Is possible the inverter can not manage twice power??
  6. S Keith
    799
    329
    AZ
    2003 Prius
    What are the subcodes? There are 25 different causes for this code.
    The problem here is that you embarked on a major modification without the knowledge or tools to do it right.
    Remove the battery. Does it go away?
  7. Thumb
    Thumb Junior Member
    Greece
    You have right I have the tools but I don't have the nessecery knowledge.
    Tomorrow I try to remove the second battery and test again...
    Is possible this modification damage the inverter???
    Is any way to connect the second battery without problem?
    Thanks
  8. S Keith
    799
    329
    AZ
    2003 Prius
    If you can't tell me the subcodes, you do NOT have the proper tools.
    I wouldn't expect so, but you won't know until you remove it.
    Paralleling NiMH is not a good idea most of the time. I have no idea if it can be done. The benefits are so limited, I can't imagine it's worth it.
    SFO likes this.
  9. Thumb
    Thumb Junior Member
    Greece
    I have the teachstream and i don't have subcodes.
    Is possible the parallel lithium?
  10. bisco
    52,497
    i really don't see what the issue could be, are you sure you connected them in parallel?
  11. dolj
    dolj Senior Member
    8,603
    4,365
    Wellington, New Zealand
    I can't imagine that it would be a simple thing to connect two batteries in parallel, otherwise everybody would be doing it. Also, presume that there would be a benefit.
    In relation to the second battery, questions that immediately come to my mind are:
    • how are the battery temps being monitored?
    • how are the module voltages being monitored?
    • how is the battery current (both in and out) being monitored?
    • how is the HV battery control module interfacing with the additional battery?
