P0A9E .One of the temperature sensor not working properly
Discussion in 'Gen 2 Prius Technical Discussion' started by khan209, Mar 9, 2019.
Tags:
  1. khan209
    khan209 New Member
    california
    I got P0A9E temperature sensor circuit too high. I took out sorted the broken wire connection with wire sorter and put it back the sensor but same code coming back. Any help?
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    Raytheeagle likes this.
  3. khan209
    khan209 New Member
    california
    Thank you SFO for the info.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,229
    5,918
    Columbia, SC
    This happens most often when someone is disassembling the HV battery and doesn't realize there are temperature sensors attached to the bottom of three modules. They attempt to remove the module and accidently stretch, bend or break one of the wires right at the sensor. Unsure of how to fix it, it typically just gets jammed back into the heat shrink or something similar.
    The best way to fix this is to replace the temperature sensor harness. That's the harness that has the three 'underneath' sensors along with the temp sensor that mounts on the upper clamp rail on the end above block 2. An alternate method is to purchase a replacement thermistor. There's a thread on here somewhere where the poster found a similar universal sensor and spliced it in.
    tangerino likes this.
