P0aa6 526-614
Discussion in 'Gen 3 Prius Main Forum' started by EdithArteaga, Jan 27, 2021.
  1. EdithArteaga
    EdithArteaga Junior Member
    texas
    2013 Prius v wagon
    I own a 2013 Prius V got the above code and had the inverter replaced. the code is still coming up and now mechanic is removing the inverted and placing the old one back due to the same code. it is also some how affecting the a/c unit. can anyone shed some light on the issue. I originally took it in for a misfire issue and the motor was changed then we started with the inverter problem.
    Massimo Pirrone likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,353
    5,398
    Pacific Northwest, USA
    That's awesome mechanic is putting the old one back... Most Toyota Stealerships will just shrug their shoulders and tell you the next super expensive part you have to pay thousands of dollars for that might not fix it... Please let your mechanic know we appreciate their honesty and fairness and let us know who it is so we can refer people nearby to 'em?
  3. Massimo Pirrone
    Massimo Pirrone Junior Member
    San Diego
    Hey did you end up figuring out the issue I’m having an identical problem. Everything is fine other wise and just swapped the inverter.
