P0AA6, car won't start unless jumped, other codes
Discussion in 'Gen 2 Prius Technical Discussion' started by dirt657, Feb 24, 2019.
  1. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I made sure it was electrolyte lol
    Skibob likes this.
  2. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Ok drove the car around again red triangle came back on this time for a p3000 detail code 123 and also for a p0a84 which is the cooling fan. Maybe have forgotten to plug it in by accident. Had a bunch of people coming over I may have skipped a step
  3. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Plugged fan in. Going to see if the other p3000 light comes off now
  4. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Brondo electrolytes? :whistle:
    Raytheeagle likes this.
  5. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    So how do I tell which module from this battery is leaking electrolytes?
  6. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Many use a hybrid compatible OBD2 scanner.
    Some have used a voltmeter on the individual modules.
  7. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I ran a voltmeter on each individual module and found all voltages were normal. Could it be someone already fixed this battery pack but neglected to clean the electrolyte off the case?
  8. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Cleaning up the case, harness, and neutralizing the electrolyte is always a good idea, then see if the code(s) return.
    If they haven't outright failed you may have to let them sit until the leaking modules show a voltage droop, which could take days.
    Or drive around while using a scanner that shows block voltages in real time, the failing blocks should show up will braking and accelerating.
    Skibob likes this.
  9. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Do you have a load tester? Wouldn’t a bad one drop voltage quicker than the others?
  10. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I do have a load tester. That’s a good point. I just figured a bad one would be much lower than the rest of them in terms of voltage.
  11. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    Load tested all 28. No bad readings. Could one still be leaking? I’m starting to lean toward the fact that they just didn’t clean the case.
  12. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    Yes, and until it has been leaking awhile it might not show any adverse voltage readings.
    If you didn't clean up the case, you should have, so if you didn't you need to strip it down clean the case and it wouldn't hurt to clean each module individually as well. That way you are starting from a known baseline. If more electrolyte shows up down the track, you should be able to easier pinpoint from where it came.
    SFO likes this.
  13. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    It’s stripped down all the way to the case. I’m working on cleaning it. It is not coming off. I’ve tried a sponge and dish soap, didn’t work. Tried scrubbing with a little vinegar. No go. Nail polish remover, no go. Any suggestions? Next it’s a wire wheel.
  14. dolj
    dolj Senior Member
    8,633
    4,385
    The electrolyte is clear (as water) and hard to see but it is just a basic (as in not acidic) solution, so any mild acidic cleaning solution should neutralise it and clean it off easily. Perhaps you are mistaking the corrosion damage to the case for the electrolyte. Without seeing what you are seeing it is hard to give specific advice on how you should proceed.
  15. dirt657
    dirt657 Member
    159
    42
    Arroyo Grande, CA
    I included the pictures above but here’s another picture.
  16. dolj
    dolj Senior Member
    8,633
    4,385
    I did see that earlier, but it is hard to tell whether that is all corrosion (which is what I am leaning to) and whether there is residual electrolyte on it or not.
    But if you have given it a good scrub with an acidic solution and then rinsed off with water and dried it thoroughly, you should only be left with corrosion damage to the case.
    I haven't had to clean up a case before, so I probably cant't say specifically what to do from here. Perhaps others who have done it can chime in with what they do.
    Is it worth sanding it a bit and then treating with some corrosion control solution?
  17. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You've got a lot of corrosion on the base of the modules.
    Y don't you removed all the modules, and clean up the metal base if the pack casing?
    As you do all the cleaning, inspect the base of the modules to see if there are any traces of electrolyte.
  18. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    As for me, I have sand it before, and applied a bit of corrosion treatment against future corrosion.
    So, it can be done.
  19. Tombukt2
    Tombukt2 Senior Member
    13,796
    2,500
    Durham NC
    Yes as in with your tongue wet finger stick to white stuff stick to tongue again determine is battery acid or not also the way you check a 9 volt battery come on now.
