P0AA6 DRIVING IN A FLOOD
Discussion in 'Gen 3 Prius Main Forum' started by franken1313, Jul 9, 2018.
  1. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Dri
    Driving fine doesn't mean your HV system is OK. You got pull off the pack cover to assess if there are water poddles in there.
    52,666
    poodles.;)
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,267
    15,525
    Bay Area, California
    2019 Prius Prime
    Hopefully their bark is worse than their bite:).
    52,666
    where high voltage gloves, just in case they have sharp teeth.;)
  5. franken1313
    franken1313 Member
    216
    27
    US
    Techstream keeps crashing when I click on datalist. Any thoughts why?
  6. franken1313
    franken1313 Member
    216
    27
    US
  7. franken1313
    franken1313 Member
    216
    27
    US
  8. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    The corrosion you see is fairly typical for the negative terminals. It's hard for me to tell, but if those are heat marks (not just oxidation) on the bus-bars, that would definitely need investigation.
    Your freeze frame info shows a 526 and 614 code. The info below was from an earlier post on a different thread, by @Patrick Wong
    Personally, if you drove through flood water, yet the battery pack is dry, I would focus on the engine compartment items.
    DTC P0AA6 means that the high voltage system has a ground fault. Normally that system is totally isolated from the car body. If a ground fault occurs, this DTC is logged.
    The bad news is that info code 526 means that the ground fault could be anywhere in the high voltage system, including the traction battery, the battery ECU, the cable that connects the battery to the inverter, the inverter, the transaxle, or the air conditioner compressor.
    BTW, there are a couple of TSBs relating to P0AA6. If info code 613 also had been logged, then T-SB-0306-08 suggests replacing the transaxle. If info code 614 was logged, TSB EG017-05 suggests replacing the inverter.
  9. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    And then read this for additional good info to help understand what you're seeing (not your EXACT situation, but good info):
    Art's Automotive
  10. ASRDogman
    ASRDogman Senior Member
    7,966
    4,046
    WOW! He is the first one I've heard that says water is NOT a conductive of water! Smart man!
    It's actually the impurities IN the water!
    That was a good and informative article. Thanks for posting the link!
  11. franken1313
    franken1313 Member
    216
    27
    US
  12. ASRDogman
    7,966
    4,046
    Time for the baking soda/water mix and a brass brush cleaning!
  13. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    Pls if you've got stuffs like these, keep them coming.
  14. franken1313
    franken1313 Member
    216
    27
    US
    Where do you see 614? Where should I be looking?
  15. franken1313
    franken1313 Member
    216
    27
    US
  16. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    In post 19, there are 2 Detail Codes (subcodes). 526 and directly below it is 614
  17. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    There is another Techstream measurement that shows a reading of 0-5v that is an indicator of how well the HV system is isolated from the car body. 5v is the perfect isolation and 0v is direct short. I don't remember the exact nomenclature for it right now, but I'll bring it up on my techstream when I get home and post it here.
    It's something....Wave or Wave..something
  18. franken1313
    franken1313 Member
    216
    27
    US
    I don't see 614 only 526
  19. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    Your photo in post 19, at the bottom of the screen clearly shows
    Detail Code 2............526
    Detail Code 3............614
  20. TMR-JWAP
    6,404
    6,094
    Columbia, SC
    And now I see the ShortWave reading in your picture on post 35 is showing a 0.03v. You have almost a dead short somewhere. Try unplugging the AC compressor. If you see the shortwave reading going higher then you're finding the problem.
    I would focus on making sure I don't have water in any of HV connections where the battery cables connect to the inverter, inverter connects to AC, transaxle, etc. Something has water in it........
    #40 TMR-JWAP, Jul 17, 2018
