P0AFA, P3004, C1259, C1310, B2243
Discussion in 'Gen 2 Prius Technical Discussion' started by Ammo, Apr 15, 2024.
  1. Ammo
    Ammo Junior Member
    0x
    Hi everyone.
    I have a Lexus with a similar system to gen 2 Prius (Lexus gs450h, 2006).
    I bought it from someone in a slightly lousy state around 5-6 years ago and managed to put some trouble-free miles on it.
    It had a few cell swaps done, initially by 3rd party specialists and eventually me and a friend of mine started swapping the cells ourselves.
    After a few diy cell swaps, I was confident enough to do it myself, so I did (you know where this is going).
    The second time I swapped the cells myself, something went wrong:
    The car booted up, but all the errors stayed and the new cells didn't fix the pack.
    I managed to do a full scan and then the car simply switched off by itself.
    I got P0AFA, P3004, C1259, C1310, B2243 and since then, we could never fix it.
    We've tried a confirmed working HV battery and that didn't help either.
    No dashboard lights, except open door light, so there is feed from the 12v battery.
    We've tried swapping the HV inverter and most of the easily accessible fuses have been checked.
    Any tips are appreciated.
  2. Tombukt2
    Tombukt2 Senior Member
    13,863
    2,519
    Durham NC
    You need to make darn certain that the hybrid battery safety plug is seated that's the last step where you push the hoop on the handle down You need to push it down smartly damn near you think you're breaking it or your finger now try it Do you have a display Yes you have a 12 volt feed but when you step on the brake and push the power button you hear no relays or anything clicking in the back correct? There's an interlock conditions have to be met. For the car to get through and out of Interlock The manual is posted somewhere some people have it in their signatures or wherever and there's plenty of reading for that.
  3. ChapmanF
    19,025
    When that safety plug isn't seated you have P0A0D.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    Scan the car right now, several systems should respond (even if it won't turn on) and might give you codes to help point the way.
    P0A0F is "the engine failed to start". On a Prius that's fairly common when the 12V battery is disconnected - which resets the ECM throttle adaptation. If the throttle bore has heavy carbon goop deposits, then not enough air gets into the intake and you have a no start.
    Or it could be something else.
    P3004 is "a problem with the high voltage system". Basically the hybrid control ecu doesn't see the high voltage it expects at some point during the "ready up" procedure.
    2 of the other codes say "hey, hybrid control has some codes" (P3004).
    Brian1954 likes this.
  5. Ammo
    Ammo Junior Member
    0x
    I should have probably specified, that the hybrid safety plug & it's fuse were inspected and can confirm that it was pushed to the max of it's hard plastic capabilities.
    When I step on the brake + push the power button, the first time you do hear a pump or relay in the back or electrical component create the usual start up sound (almost like music to my ears at this point), but the sound lasts 1 second and no reaction to anything else. Power button stays unlit.
    As we have tested the car with a confirmed working battery, this seems to be a problem with the battery's connectivity to the car, rather the actual battery, as the working battery still gave us no control, lights etc.
    I will research the interlock manual, many thanks.
    We've attempted to scan it, there is no feed to the obd2 at all.
    The last scan yielded me the above error codes, minutes before the car lost all power, to never be started again.
    P0AFA is the one that's in question, but thanks for the P0A0F.
    Yeah, I'm familiar with the other codes.
    We've also found that the non working battery had potential burn marks in one of the cables/connectors, but nothing has been melted or altered physically, just a small black smear sort of here, I highlighted it in black.
    Upon dismantling the battery, before the car's last known working start up, I've had a small spark on this cable, highlighted in red.
    I was wearing PPE, so no harm done.
    Not sure how much help this results in, but good information to know.
    Your help is much appreciated.
  6. mr_guy_mann
    4,118
    2,014
    NJ-USA
    OK, that might change things some. I don't have a diagram for your car BUT, on a Gen2 Prius, the HV battery ecu has the termination resistor for the CAN bus network. If that is damaged, it can disrupt all communication on that bus.
    The Prius has a second network for scantool comm for some systems. Again, not sure on details for your car.
    One test, disconnect the 12V battery and carefully measure resistance across the OBD connector pins 6 & 14 (don't spread the terminals). Should read about 60 ohms.
    maleko likes this.
  7. Ammo
    Ammo Junior Member
    0x
    All combinations of OBD pins are showing open line, including the 6 & 14.
    Rest of the fuses seem fine, the last one to confirm is the 150A one under the fuse box.
    Some other interesting findings:
    Some of the circuits are still working, that includes headlights on low & high, interrior spot lights (even the obd side light), horn, emergency button turns on the indicators, central locking system is working, but the seats, wiper stalk, indicator stalk, windows, sunroof are not working.
    Attaching some pictures of the fuses & a video of testing.
    Can't post the full link via text
  8. Tombukt2
    13,863
    2,519
    Durham NC
    This sounds like a generation 3 but okay.
  9. Ammo
    Ammo Junior Member
    0x
    Could be, it's not a Prius, as stated.
    Anyhow, to everybody else, this seems to be a fusible link issue, will be investigating it.
  10. Tombukt2
    13,863
    2,519
    Durham NC
    Be interesting to see how that pans out that have been like one of the first things that gets looked at and one of the first things that will be seen that's burnt up It's right by the battery or whatever usually so in the general grand scheme of things it gets seen pretty quickly interesting.
