P0B65 engine code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Arob21, Mar 31, 2022.
  1. Arob21
    Arob21 New Member
    24
    Washington
    I have a prius that has a engine code p0b65, this code make the car run off the engine 100% of the time.
    The car has sat for 8months. I just replaced the 12v battery.
    Has anyone else ever had this code and what ended up fixing it?
    I have done a ton of research and havnt font anyone else that's had this code....
    Lucky me
  2. PriusCamper
    PriusCamper Senior Member
    13,170
    5,327
    Pacific Northwest, USA
    Did you replace with fully charged 12v? I'd start there... And if you made the mistake of buying an Optima 12v, just get your money back and buy a real 12v that's not built by criminal con-artists.
  3. ChapmanF
    18,673
    That's not an engine code, it's a code about the voltage sensor wiring inside the traction battery (the large, high-voltage one). There are 15 such sensor wires, the − reference and one for each of the 14 pairs of modules (28 modules in the pack). Your P0B65 is telling you the ninth one of those is reading less than 2 volts.
    That's a completely unrealistic reading for a pair of 7.2 V NiMH modules, normally more like 14 to 16 V, so a reading < 2 V is not really telling you anything about the modules, it's telling you the voltage sensing connection is kaput.
    Arob21 likes this.
  4. Arob21
    Arob21 New Member
    24
    Washington
    Thank you for pointing me in the correct direction! The tueminals on the hv battery have a decent amout of corrosion on them. I just havnt cleaned them because I don't know much about hv batteries and don't feel like dieing over a prius.... do you think that could have something to do with it?
    And it is a 2012 prius v, are these wire sensors your talking about located on the hv battery?
    Thank you
  5. bisco
    52,502
    if you're not comfortable, you need to take it to someone who is. corrosion is prius worst enemy, and definitely your problem.
    the battery needs to be opened up ans thoroughly inspected and cleaned.
    even then, sitting that long might have damaged some modules
  6. bisco
    52,502
  7. Arob21
    Arob21 New Member
    24
    Washington
    Its kinda interesting that it says the battery coolant pump could cause the code. I have a code for the inverter water pump. But I just replaced it a couple days ago and the code still is on. But I was having problems with this hv battery code months before this waterpump code popped up
  8. ChapmanF
    18,673
    Umm, out of the three links bisco provided, the only one that says that is the third one (from "Parts Avatar"), and the only reason it says that is because it's wrong.
    Wrong for a Prius, that is.
    I've posted a few times in other places about the danger of internet searches for trouble code meanings, for codes in the manufacturer-defined ranges, like P1xxx codes. You can get explanations for a code that means some completely different thing in some other car, and be sent on a totally wrong track.
    This example is a little different. P0 code meanings are standardized by SAE, so in any kind of car that can give a P0B65 code, the code is going to mean the car is a hybrid or electric, it measures its traction battery voltage in at least 9 places, and the 9th measurement is bogus. So you can safely learn about that much in an online search, as far as it goes. But beyond that you still have to be very careful.
    Because that "Parts Avatar" page is trying to cover what P0B65 might mean for any car that can say it, the page has to include things like "battery coolant pump" because some hybrid or electric cars may have one.
    A Prius doesn't have one, though. Its battery is air cooled. The other code you have, P0C73, refers to a pump that is under the hood and cools the transmission motor/generators and the power electronics. That pump has nothing to do with cooling the battery, and your P0C73 is not related to your P0B65. It's just a second issue.
    You can see here again the kind of red herrings you can run into by looking up your trouble codes any place other than the repair manual. The repair manual for a Prius tells you exactly what each code means in a Prius. Generic online pages covering what the same code might mean across all possible cars won't tell you that.
    Ironically, even as SAE standardizes more and more trouble codes, that still doesn't help as much as you might think. In a Gen 1 Prius, an inverter cooling pump issue wouldn't give a P0C73 code, it was P3130 (in the "jointly defined" P3 range), because of course there weren't a lot of SAE standardized codes for hybrid vehicles yet. So you would have to look that code up in a Prius repair manual, and when you did, you would learn exactly what pump that is, and what things it cools, and how it is operated.
    Fast forward to Gen 3, and hybrid cars are now enough of a thing for SAE to have standardized a bunch of codes for them, so now there is a P0C73 code (in the SAE-defined, P0 range), and Toyota updates their firmware to give that code instead. Now you can look it up other places online, because it's a standard code.
    But as a standard code, now all it means is something like "this car has at least one cooling pump somewhere related to the motor electronics, and the one considered 'pump A' has some kind of issue." To find out the specifics, like what pump this really is and what things it does and doesn't cool, you still have to look in the Prius repair manual.
    It could be possible that some other car even has a "motor electronics coolant pump A" that has something to do with cooling the battery. But the one in a Prius does not.
  9. Arob21
    Arob21 New Member
    24
    Washington
    Chapman you should definitely have your own auto Repair business... you a smart guy. I'm going to post a few pictures of the bus bars and some sort of module that I just seen that also looks terrible
  10. ChapmanF
    18,673
    How that voltage-sensor module looks on its outside is only skin-deep, but that orange connector on it (and the skinny wires connected there, leading out to every second battery module terminal) are the window into its soul.
    (That orange connector also carries well over 200 volts DC if the service plug is in, and still over half that even with the service plug pulled, so is not to be handled without precautions.)
  11. Arob21
    Arob21 New Member
    24
    Washington
    Yeah this has become a bit over my head. I think I'm going to take it to the dealer and pay to have them diagnose it. Then from there I'll determine if it's something I'm able to take on or not. I just know they are gona take 1 look at it and say it needs a whole new hv battery and a bunch of other bs without actually finding the specific true cause
  12. ChapmanF
    18,673
    That is undoubtedly what a dealer will say, because that "frame wire #2" with the skinny sense wires, which could be ordered as a separate part in earlier generations, is not for sale as an official Toyota part in Gen 3.
    So what will happen is the dealer will give you a price, and you will have to think carefully about whether the car is worth putting that kind of money in, and that will be a hard decision.
    The only chance I can see to improve on that would be to find a hybrid-qualified independent shop that isn't a dealer (and may have some of those wire harnesses available, salvaged from other batteries), or DIY.
    2010moneypit? likes this.
  13. bisco
    52,502
    how many miles on her? have you done any major repairs?
  14. Arob21
    Arob21 New Member
    24
    Washington
    110k miles, I have only owned it a year. It was a buddy of mines car. They hit a wood crate that fell off a truck on the freeway. They decided that didn't want to fix the car so I bought it from them for $2500 and repaired the body damage. It's been a slow process and I think all these problems have developed over time with it just sitting.
  15. bisco
    52,502
    yeah these cars don't like sitting. once you get the battery sorted, look into 'egr circuit cleaning'
  16. Arob21
    Arob21 New Member
    24
    Washington
    @ChapmanF Hey so I picked up a 2014 prius that was wrecked but was otherwise working fine. I swapped the hv battery to my 2012 so that should all be good. I went through and checked every fuse in the car and replaced 1 the was blown under the dash. The car has a brand new 12v battery.
    All the lights work but the car won't start and won't even go into accessory mode. I'm not sure what to check next. Iv looked at all wires I can see and it doesn't look like any have been chewed on by a mouse. There has definitely been one in here chewing up papers and making a nest but I can't fine any wire damage. Is there anything else you think I should check before ripping out the seats and carpet to check if any wires under there have been chewed.
  17. Arob21
    Arob21 New Member
    24
    Washington
    @ChapmanF Nevermind, I left my other car hooked up to the 12v for like 1hr and went out and it started. My hv code is gone! Thank God. Now I just have to figure out my P0C73 code. I replaced the pump already so km not sure why I'm still having problems. I don't see any inverter coolant moving in the resivor.
    But I really appreciate the time you took to help me with my questions!
    Thank you
