P0B6A, P0B79, P3004 after battery cell replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dklayton0213, Jun 2, 2019.
Tags:
  1. dklayton0213
    dklayton0213 Junior Member
    35
    16
    Hattiesburg MS
    Like the title says. Replaced 4 battery cells and now this on a 2011 Prius. I got the freeze Data if anyone is interested. Any help is appreciated.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,530
    Bay Area, California
    2019 Prius Prime
    Did you balance the pack, or just swap the modules?
    What’s the age of the new modules?
    Do you know their capacity and how they compare?
  3. dklayton0213
    35
    16
    Hattiesburg MS
    Yes we balanced the pack. The new modules are refurbished and reading 7.71. Some of the details of the error codes are showing 00 volts for block 13 but we didn't touch that block. It did spark when we put the bus bars on. Maybe shorted something out?
    mjoo likes this.
  4. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,099
    Columbia, SC
    Those P0B codes are for low voltage on a block. Sounds like you probably have either a sensor harness problem or ecu issue. Maybe damaged/cracked sensor tabs
    mjoo likes this.
  5. Raytheeagle
    11,269
    15,530
    2019 Prius Prime
    Did you check for corrosion? You only touched the modules and blocks with issues? What torque did you use on the bus bars?
    mjoo likes this.
  6. dklayton0213
    35
    16
    Hattiesburg MS
    Yes, yes, I don't have a torque wrench. I just tightened it tight but not too tight.
  7. dklayton0213
    35
    16
    Hattiesburg MS
    Update: turns out it was the wire. Ended up just replacing the whole battery though
    Raytheeagle likes this.
  8. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Thanks for checking back.
    It's nice to get resolution after folks provide feedback advice on a problem.
