P102D - Check engine on 2011
Discussion in 'Gen 3 Prius Main Forum' started by itengineer, Nov 28, 2022.
  1. itengineer
    itengineer Member
    86
    25
    Minneapolis
    Hi All,
    Your advice needed on this issue
  2. ChapmanF
    19,025
    P102D is a weird code, reporting a higher-than-expected current flowing through the heater circuit during the OFF portion of the control pulse. (That's what makes it weird.)
    It shares the same troubleshooting steps with the other O₂ sensor heater codes, so you could check the resistance of the heater, the wiring continuity and so on. But the business of current flowing when the power transistor ought to be OFF might be harder to find a cause for outside the ECM itself.
    Mr. F likes this.
