P1080, P3022
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 04 Prius, Aug 12, 2017.
  1. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Hey all,
    I just took our new to us 2006 on a maiden test drive today, & got a P1080 & P3022 code. The car frequently cycles on & off for short intervals, the battery fan is running full speed, sometimes has normal power sometimes very poor driveability, the battery was at first charging but by time I got home appeared to no longer be. When it was charging it went from 2 purple bars to fully green in a little under 2 miles, then back to one bar in a few more.
    Now, the backstory. We got this car last month with minor front end damage to the left fender.& coolant canister. It ran & drove, (not far without coolant) the PO didn't want to pay the body shop for repairs, stated it was his DD car & ran awesome. The body shop had run the 12v battery dead for the week & a half they moved it in-out daily & were jump starting it @ the front left fuse box terminal. The car looked to be well cared for, has 169k on it, so we got it & I straightened the front & repaired everything. While going over the car I noticed evidence someone had previously been into the hybrid battery, parts were not properly assembled & missing hardware, I did not open it up but repaired all the misassembled parts & missing hardware I found, removed & cleaned the battery fan & intake duct.
    So. Tomorrow I'll open up the battery to see what I can find, but I'm suspecting it has a reconditioned hybrid pack that probably didn't like sitting idle for a month. Any thoughts?
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,840
    Clearwater, Florida
    Yep hybrid battery from WAM INDUSTRIES.
    Whack A Mole battery repair found at just about any Craigslist out there.
    The nuts and bolts and buss bars and battery interconnect are corroded and many bulging modules.
  3. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Got both batteries out today & the covers off, the car with the codes has some corrosion on a few terminals, but overall not bad. It looks to be a Renan though with different cell block markings.
    The donor car battery has noticeable corrosion on all terminals, & what looks like evidence that ekectrolyte has in the past oozed along the bottom pan. It also appears to be a reman. So, other than voltage readings, is there any other checks I can perform on the cell blocks? Also, the code referred to "block 12 weak" is that counting the physical cell blocks, & which end do I count from?
    52,878
    see some of the battery rebuilding threads here. everything you ever wanted to know, and more.
    04 Prius likes this.
  5. JC91006
    16,937
    8,647
    Start counting from the opposite end if the electric ecu, first block is module 1 and 2, 2nd block is 3 and 4.........
  6. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Thanks for the input, I'm going to invest in some tooling.
    One more question, I need to have the car smogged by tomorrow, so, using a voltmeter, the pack from the parts donor car reads 8v on all cells except one that reads 7v. The pack I took out of this car has 5 cells that read 7v. Would it be ok if I borrowed one of the better 8v cells from this pack & swapped it into the better pack in place if that one low cell without doing any equalizing? My knowledge of (lead acid) batteries in general thinks this would actually be better than leaving a low cell in play, am I wrong?
  7. JC91006
    16,937
    8,647
    The minimum voltage on a module should be 7.2v, and even then that would be extremely low charge.
    I think your pack would need to be charged and balanced, then probably have the weak failing modules replaced. Putting in a 8v module (that's on the high end) probably won't work well. 8v resting voltage modules are rare so you should check after it's rested for a few days
    Are you in possession of 2 complete battery packs?
    #7 JC91006, Aug 14, 2017
  8. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
  9. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Yes, I have a parts car that has frame damage, both vehicles run so I let them both go thru the charge up stage yesterday when I pulled them in the shop until the engines shut off on their own. Both packs have sat since yesterday afternoon out of the cars. I don't have a charger/balancer yet as this was an unexpected thing, I know the right way to do this after researching threads today, but until I have the tools I'm hoping to find a quick solution to get past the emissions testing before my tags expire.
  10. JC91006
    16,937
    8,647
    You probably shouldn't have started the car that's been sitting....that for sure will kill a drained battery. That start up at 100A+ current usually will bring a weak module to unusable state.
    Anyways, if you let everything sit for a few days and pick out 28 modules that are similar in voltage (7.5v - 7.7v) is my guess on the range, then it should be OK to use.
    But this is still a short time fix, it probably won't last long until you charge/condition/balance the pack.
  11. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Ok, sounds good, thanks.
    The parts car hasn't sat much, maybe a few weeks at a time. I always let it charge when I run it, sometimes I run it up the road & back. I've only had it a few months. It's pack read 220v before I took the buss's off to check cells, the one that's giving me issues read 116v, and it was driven 15 miles yesterday. The good car did sit almost 2 months before the repairs were completed, with a drained battery from the body shop starting it twice a day & shutting it off quickly (no engine coolant). Might be what killed it.
  12. JC91006
    16,937
    8,647
    If you let any 10+ year old Prius sit for 2 weeks, you are setting yourself up for a battery failure.
  13. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    True, I have intended to come up with some sort of battery tender for it
  14. JC91006
    16,937
    8,647
    Oh no, there's no battery tender for the HV battery, just need to drive it.
  15. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    That's hard to do with an unregistered parts car that has frame damage, a cracked wheel, & the brakes feel like the old manual drums....
    I see a need for a new invention......
  16. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    Just got done cleaning up the buss's, used the best from both packs, I'll bring my meter home from work tomorrow, to do another check of cells, it's way better & accurate than the basic one I have here now (this one only rounds to the nearest volt)
  17. JC91006
    16,937
    8,647
    Where are you in Shingletown?
    A battery will be fine left unused.....BUT if you want to use it again, you would need to charge it first. Otherwise, it all goes out of balance and become useless.
    So if you have a battery that has sat a month and you start the car with it....chances are, it'll be so out of balance, some modules will die
  18. JC91006
    16,937
    8,647
    I still suggest you somehow charge this up before using it.
  19. 04 Prius
    04 Prius Member
    74
    32
    Shingletown CA
    I'm in the lower foothills, 22 miles out of Anderson. Off grid homestead out in the sticks.
    Due to the individual cell discharge I could see that easily happening.
  20. JC91006
    16,937
    8,647
    Self Discharge is what kills these batteries. Either from age or helped with corrosion buildup.
    All 28 modules will be deteriorated at a different rate. Some will still have good capacity, while some are weak with very little capacity left. Those are the ones left to die
