P1121 and P1116 Under Warranty?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by speedy_bee, Oct 25, 2022.
  1. speedy_bee
    speedy_bee Junior Member
    los angeles
    Hi there!
    I'm new to Prius Chat so my apologies if this question has been asked before.
    I'm in California and my 2008 Prius with 120k miles on it failed a smog test with the failing codes being P1121 and P1116. My understanding is that it's the cooling system and a valve needs to be replaced.
    My question is: Is this repair covered under my warranty? The dealership is saying it's not but the handbook makes me believe otherwise. I want to know what system these codes fall under either Performance----Defect----Hybrid Battery.
    I've also been told that they won't know if it's under warranty until they run a diagnostics. I just got my catalytic converter stolen and replaced and I am not keen to spend another 200+ just to figure out what's wrong with it.
    Thanks for your insights!!
  2. JC91006
    16,936
    8,647
    The emissions warranty for CA is 15 years or 150k miles. So you probably are covered for an emissions related failure.
    SFO likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    Since the car has failed a Smog Check test, it’s the Performance Warranty coverage that applies, subject to its terms and exclusions. As the Owner’s Warranty Information (PDF) booklet states on page 22, that warranty covers “all necessary repairs and adjustments [...] to ensure that your vehicle passes the test.”
    I’d suggest confirming the following:
    • The car is within the 15-year time limit. Some 2008 model year vehicles might have been built and sold in 2007, so check the date of first use on Toyota’s Vehicle Specification page. You can also check the manufacturing date, listed in MM/YY format on the certification label inside the left front door. If either date is on or after November 2007, the time limit hasn’t yet been reached.
    • The car is within the 150,000 mile distance limit. That should be obvious, since you’ve said the mileage is 120,000 or so, but make sure that the odometer is working, the title doesn’t indicate an odometer discrepancy, and there aren’t any labels indicating that the odometer was replaced.
    • None of the other exclusions stated under “What Is Not Covered” on pages 12, 13, and 24 applies. Note that the exclusion for salvage or total-loss vehicles “does not apply to the emission control warranties.”
    You could then take the car back to the dealer. As described under “If Your Vehicle Fails a Smog-Check Test,” page 26, be sure to give them a copy of the Smog Check report.
    That’s the catch-22 of warranty repairs. The booklet states on page 21, “Where a warrantable condition exists, Toyota will repair your vehicle at no cost to you, including diagnosis, parts and labor,” but you might have to agree to be responsible for the dealer’s diagnostic fee, in case the cause turns out to be one that wouldn’t be covered, such as damage from vandalism or rodents eating the wires, or a faulty hybrid battery, for which coverage ends after 10 years. The latter is unlikely; the Repair Manual (more info) procedures for diagnostic trouble codes P1116 and P1121 don’t list the hybrid battery among the potential trouble areas.
    If the dealer still insists on a diagnostic fee in advance, you can follow the steps under “If You Need Assistance,” pages 4–5: ask for the dealer’s customer relations manager, call the Toyota Customer Experience Center (1-800-331-4331), and if necessary, make a claim under the California Dispute Settlement Program. Because Toyota was required by California regulations to offer the Performance Warranty, you could also complain to the California Air Resources Board (1-800-242-4450).
    JC91006 likes this.
  4. Owner of "Little Green"
    Owner of "Little Green" Junior Member
    Boulder, CO 80304, USA
    What happened with this? Did you get it covered? If not how much was it? I had my catalytic converter stolen, then covered, now I am getting those same two codes, among other things that happened after I covered the cat. If the warranty didn't cover it, how much did it cost to fix these?
  5. dolj
    dolj Senior Member
    8,637
    4,390
    Wellington, New Zealand
    You can answer the "Did you get it covered?" yourself by reading #3 above.
    These codes are not at all related to your catalytic converter saga, so you can put that out of your mind.
    A competent mechanic with some previous experience should be able to handle this without the need to go to a Toyota dealership. Insist on OEM parts though.
    $300- $600 should cover both codes.
