P1121 - just assume coolant control valve?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Julie J, Jun 28, 2023.
Tags:
  1. Julie J
    Julie J New Member
    san antonio, tx
    SE
    Ok, I know zero about cars but a quick study. 2009 Prius, 85k miles. Runs great. No obvious problems except for check engine light.
    With p1121 code, can I just assume it's the coolant control valve and skip the costly diagnostics on all 4 potential issues listed? Sounds like it's been known to stick, and until 2010ish, the valve was the only potential issue under p1121? Something like that?
    And, given that, is there anything I can do myself to try to eliminate other possibilities? Check coolant? I can do that. Check wiring connections on valve or other potential culprits .... Can I do that?
    I can pop the hood, make it stay open, jumpstart the car, and believe it or not pop the trunk with no power from inside the car. It is ridiculously complicated if you're not a contortionist. But that's about it.
    Very grateful for whatever advice you can provide. Thanks, julie
  2. PriusCamper
    PriusCamper Senior Member
    13,396
    5,411
    Pacific Northwest, USA
    I'm impressed with how quick you figured out the right answer to p1121. You probably know way more about cars than you give yourself credit for. And yes a 2009 w/85K is my dream car... I could get so much life out of that!
    Do you have a friend or family member that can work with you on this stuff? For example fixing the p1121 is only a $42 part: https://www.ebay.com/itm/394097566363 and if had someone with a little experience with hoses and a bunch of hose clamps to coach you up you could fix this yourself in a couple hours for the cost of the part. Whereas if you were dependent on a hybrid shop you'd be looking at $600 instead.
    As in what's your budget like for when issues like hybrid battery and brake booster pump come up? As long as you have the budget/plan for that, then this Prius will be insanely reliable for you.
  3. Tombukt2
    Tombukt2 Senior Member
    13,799
    2,501
    Durham NC
    Yes replace the coolant control valve You can even kind of hear it making noise and whatnot at times many times with this system and in this car with that code just replace it and be done with it or you can spend the afternoon running the diagnostics and playing around only to change that valve anyway $42 is really not throwing parts at anything It's a near 100,000 mile part and many years old and a known issue.
    PriusCamper likes this.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,109
    2,011
    NJ-USA
    While there is always the possibility that the car has a problem with wiring or a connection, I have not seen or read about any Gen2 Prius that P1121 wasn't the coolant valve.
    Most here recommend using a Toyota part as most reliable. AfterMarket parts are less $$ but can fail sooner.
  5. PriusCamper
    13,396
    5,411
    Also, it's worth mentioning that many people go years and years ignoring this problem without much consequence other than loss of MPG. And I'm not saying that's the right option, but it is an option.
  6. pasadena_commut
    pasadena_commut Senior Member
    3,001
    931
    Southern California
    If the OP chooses to fix this, one of these:
    Astro Pneumatic 9409A Hose Clamp Pliers | JB Tools
    will come in handy. It doesn't have to be specifically that one. Spacing is really tight and the usual sort of "put a big pair of pliers on the clamp" approach won't work.
    My son helped me with this, and even so, it was kind of a PITA. We ended up releasing two of the three hoses to the 3 way valve at the end away from the valve because there just wasn't enough room to easily put them on with the valve in place. That is, old one out with those two hoses, transfer the hoses to the new one in exactly the same orientation, and then install the new one. One of the hoses has easy access, that one was released at the valve and later reattached when the new valve was in place. Even with the inverter cranked up and wedged with a 2x4 getting the valve out the top was really hard. We ended up taking it out and putting it back in from the bottom.
    There is a long thread about this issue, read the whole thing before trying it yourself.
    P1121 - Coolant Control Valve Replacement (with pics) | PriusChat
