P1121 Valve Replacement/Time to move on?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GucciWhite, May 16, 2016.
  1. GucciWhite
    GucciWhite Junior Member
    16
    san diego
    Dealer said Charge is about 550$. Isn't the coolant replaced when the valve is changed?
    ETP likes this.
  2. JC91006
    16,939
    8,647
    I don't know if the dealer will do it (even if it says they should do it).......It's all about saving time. The faster they finish, the more money they can make. Many have said, they clamp the hoses and not change the fluid.
  3. Currahee
    Currahee Member
    103
    34
    CT
    I would shop around, check dealer coupons. Mine was $210 labor $135 parts a couple years ago. I assume they just clamped off the hoses but who knows.
  4. ETP
    ETP 2026/2021 Prime/24 Venza Limit/B52-D,G,F,H
    2,806
    1,170
    Auburdale FL
    I suspect you will find a lot in SD. Check the club forum section.
    SoCal : 04-16-16 (SAT) Chemical Guys/PriusChat Detailing Event !!! Gardena | PriusChat ouch Thanks, great info for parts.
    delete
  5. GucciWhite
    16
    san diego
    Does anyone happen to know the part # needed for p1121? Called and they said there's 3 different valves I can choose from..
  6. JC91006
    16,939
    8,647
    16670-21010 There's a guy selling on here/ebay right now. Look at the "for sale" section
