P1122, P0446,P0606,P0172
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Paul Schenck, Nov 30, 2018.
  1. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    Cleaning a MAF will not do a thing for rich codes, they do not work that way, it would make the condition WORSE if it did.
  2. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    I did not say this is for sure the reason for Paul's P0172, just that it's been a quick and dirty "fix" for me the last 4 or 5 times my daughter's '07 has coded P0172 for the past 1/2 dozen years. I use quick and dirty "fix" to imply no diagnostics are performed aside from Techstream confirmation that the code goes away and fuel trims return to normal post maf/tb cleaning. This on a car which passes NYS emissions yearly without issue, despite some knucklehead (me) using maf/tb cleaning to beat back P0172.
    Maybe I'm misunderstanding you here, but are you saying a dirty maf won't or can't cause P0172 and that cleaning a maf cannot remedy P0172?
    Raytheeagle likes this.
  3. Paul Schenck
    Paul Schenck Active Member
    524
    307
    Fresno, California
    Took the valve I had replaced recently as it was easy to get to. Here is what I learned, and what I found inside. Like Patrick said putting voltage to the motor wires (pink and Black on the valve side and purple and yellow at the connector. I used 18volts because it was handy. You can see the results of the test on the paper. There are only 5 wires however less than I expected.
    The motor didn’t turn at first so I opened the valve up making it easy to see what goes where and why. After removing the worm gears I could spin the motor with my finger so I applied voltage again and everything works as it should.there does seem to be some grit ?? Which I cannot explain so I’ll have to investigate a bit more and clean it up before I trust it.
    Thanks for the help IMG_6966.jpg IMG_6968.jpg IMG_6957.jpg IMG_6961.jpg IMG_6959.jpg IMG_6965.jpg
    iPhone ?
    SFO and m.wynn like this.
  4. Paul Schenck
    524
    307
    Fresno, California
    This valve made it 397,000 miles before engine failure you can see the radiator flush at 200,000 was not enough to keep things pristine.
    iPhone ?
  5. Cammac
    Cammac Junior Member
    Charlotte
    Hey Paul sorry to bump this older topic but did you ever get the P1122 code figured out? I’m dealing with a similar issue after replacing my CCV
  6. Paul Schenck
    524
    307
    Fresno, California
    Patrick and I decided it was a code thrown because of the P0606 ECU processor
    iPhone ?
    SFO likes this.
  7. redwald
    redwald Junior Member
    Orangevale, CA
    Hi Paul, hope you're still around after a year.
    I just replaced the Coolant Control Valve but am still getting the P1121 & P1122 DTC. Do you remember if you had to replace the ECM to cure this ?
    I haven't yet done a complete drive cycle to try to clear codes yet, still trying to research how many miles, starts, stops, speed, etc I need to do. Hopefully that will clear the codes, I need to get this car smogged. Oddly enough the CEL (MIL) isn't lit on the dash.
  8. Paul Schenck
    524
    307
    Fresno, California
    Mine corrected the code immediately
    iPhone ?
