P2024 any ideas how to fix?
Discussion in 'Gen 3 Prius Main Forum' started by Prius2012 jordan, Jun 23, 2020.
  1. Prius2012 jordan
    Prius2012 jordan Junior Member
    Jordan
    Check engine on p2024 code any idea how to fix it
    52,880
    what does that code refer to?
  3. Prius2012 jordan
    Jordan
    Evaporative Emissions Fuel Vapor Temperature Sensor Circuit
    52,880
    first thing to do is make sure the gas cap is tight, and also that it is not damaged.
    do you have any symptoms or warning lights?
    Johnny Cakes likes this.
  5. bisco
    52,880
    if that isn't a problem, you'll need to check the wiring to the ecu. do you have access to tech stream and service manual?
  6. Prius2012 jordan
    Jordan
    Yes i do have access to tech stream
  7. bisco
    52,880
    excellent. that should direct you to the relevant troubleshooting section of the service manual
    Prius2012 jordan likes this.
  8. Prius2012 jordan
    Jordan
  9. bisco
    52,880
    techinfo.toyota.com
