P2237 code after topping off AC freon
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priusfanboy, Aug 23, 2023.
  1. priusfanboy
    priusfanboy New Member
    I had an ac issue with my 2009 white prius where the air did not come out of the vents cold enough. I opened a thread here on priuschat and received many helpful comments.
    AC starts off warm but gradually gets colder after several minutes of driving | PriusChat
    so, i then topped off the freon in my prius and the ac was working as it should - nice and cold. I went home and turned off the prius.
    the issue:
    later i took the prius for a drive and shortly into the ride i saw the CEL. i used my OBDII reader and it was a P2237. wt !?!?!?!?
    I have researched the P2237 and do not see how it can be related to topping off the freon. but, it started on the first new ride after topping off the freon. so, it is either a major coincidence (i am not thinking so) or somehow the freon top off affected the sensor in away that is not obvious.
    i clear the error code but the same thing happens every time i take a ride. the ac continues to work fine. the car continues to drive fine.
    I have researched the P2237 code here on priuschat and elsewhere. I see mixed explanations of what can be done or was done - for example: changed the sensor did nothing in many cases.
    any ideas on where I can start to try and debug this issue?
  2. Tombukt2
    Tombukt2 Senior Member
    13,508
    2,430
    Durham NC
    I doubt the '02 code has anything to do with your air conditioning unless you unplug something broke wire who knows I think that's for the lower one on the converter too isn't it? So it's time to troubleshoot that at least you don't have the PO420 code the catalyst below threshold might not ever get that fixed. Without a factory converter and factory O2 sensors that is which would be more costly than the brake accumulator and what have you.
  3. ChapmanF
    18,606
    Coincidences aren't major or minor. They're just things that happen around the same time.
  4. priusfanboy
    Thanks for the helpful comment. if true, it would explain what otherwise appears to be a coincidence involving two unrelated components.
    i will look around the area where the freon input valve is see if anything could have been disturbed. Perhaps when i nudged some things out of the way to get to that valve i disturbed something.
    it is the upstream sensor (if I understand correctly), so I will follow the wire path from the sensor itself back up into the engine bay where the sensor clips in.
    P2237 OBD-II Trouble Code: O2 Sensor Positive Current Control Circuit/Open Bank 1 Sensor 1
