p2601 and humming noise
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by k1ngn0thing, Apr 24, 2022.
Tags:
  1. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    2007 prius p2601 and humming noise - YouTube
    is this safe to drive? I did 80 miles in one day with no more than 20 minutes between stops with no apparent overheating so I'm hoping it's just the CHS pump and not integral to cooling.
  2. PriusCamper
    PriusCamper Senior Member
    13,465
    5,431
    Pacific Northwest, USA
    Kinda sounds like air in inverter cooling system that needs to be bled out... And you got P2601 as a recurring error code, or just once?
  3. k1ngn0thing
    k1ngn0thing Member
    205
    51
    MA
    2016 Prius c
    cleared it and it came back after 50 miles. about this time last year I did replace the inverter pump, but I was under the impression this code wasn't for the inverter cooling system.
  4. PriusCamper
    13,465
    5,431
    Yeah, the code isn't, but the sound kinda sounds like there's still some air in the system from when the inverter was replace. So sound and code might not be related. And if it's just the CHS pump, it just slightly lowers MPG when engine is cold, so easy to live with. Least expensive fix is getting one at a junk yard and pulling it yourself so you have a good sense of what it will take to install it.
