P261B Estimated Water Pump Life
Discussion in 'Gen 3 Prius Main Forum' started by MexicanChip, Dec 6, 2020.
  1. MexicanChip
    MexicanChip New Member
    Las Vegas, NV
    image.jpg Hello please post the mileage when you had your water pumps replaced. I’m trying to get a log of how long these typically last from people on this forum.
    I replaced my water pump at 86,432 Miles
    2015 Toyota Prius 3.
    Thank you!
    SteveSco and Mendel Leisk like this.
  2. AzusaPrius
    AzusaPrius Senior Member
    2,258
    952
    MexicanChip likes this.
  3. PriusWave
    PriusWave New Member
    16
    Los Angeles
    I think you replaced it at the perfect mileage. I own a fleet of Priuses and I change the pump between 80,000 and 100,000 miles.
    If I buy a used Prius with over 80k miles, the first thing is do is replace the pump.
    The Gen 3’s rarely throw a code for a bad pump.
  4. Paul E. Highway
    Paul E. Highway Active Member
    210
    131
    Hawaii
    156,888. Preventative maintenance.
    Raytheeagle likes this.
  5. Mendel Leisk
    42,380
    First engine coolant change is 100K miles or 10 years, whichever comes first. As long as it's the miles that comes first, maybe that's a good time to replace engine coolant pump (aka water pump). Similarly for Inverter coolant pump, at 150K miles or 15 years*? Both are subsequently 50K miles or 5 years, so if the months governed (miles were much less), then do it at a subsequent interval where the miles are about 100K.
    * US Schedule. Canadian Schedule says to change both coolant circuits at 100K miles (160K kms) or 10 years.
    #5 Mendel Leisk, Dec 9, 2020
  6. Mendel Leisk
    42,380
    MexicanChip and Paul E. Highway like this.
  7. Mendel Leisk
    42,380
    Window shopping a little. The OEM pump is indicated as "out of production" here, and the Aisin WPT190 is recommended as compatible (same?):
    AISIN WPT190 PUMP, WATER - Amayama
    Above link is about $20 cheaper for me (with shipping), than amazon.ca:
    Also, Amayama does not charge sales tax or import duty, at least not this far, on small items I've purchased.
    #7 Mendel Leisk, Dec 9, 2020
  8. Xterra72
    Xterra72 Senior Member
    1,437
    1,684
    High Temperature light flashed.
    Replace Engine Water Pump at 175k.
  9. Stangar
    Stangar Active Member
    174
    175
    Palmdale, CA
    208,222 miles as preventative maintenance.
    Also, you might as well change the engine thermostat also as it is in close vicinity.
    MexicanChip and Xterra72 like this.
  10. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    Buyee.jp has the WPT190 listed at $139.40. It’s about $40 for DHL shipping from Japan for up to 5kg weight.
  11. tvpierce
    tvpierce Senior Member
    951
    883
    Maine
    2013 Prius v wagon
    I stopped buying auto parts from auction sites and Amazon sellers unless they're traditional businesses -- like a Toyota dealership, or the Denso's store, etc. Too many counterfeit parts out there. I got burned on "OEM iridium spark plugs".
    The Denso water pump is available at RockAuto for $192, and you know you're getting a Denso part.
    KevininFl likes this.
  12. Mendel Leisk
    42,380
    With shipping, say to lower 48 States?
    Amayama I strongly suspect will never have counterfeit parts. Purely a hunch, but that's their bread and butter. For me in Canada it's worked out well so far; a lot of US retailers won't ship to here, or shipping is too much.
    Paul E. Highway likes this.
  13. cnc97
    cnc97 Senior Member
    1,422
    1,536
    38
    Evansville, IN
    To complicate the matter further, Toyota of Louisville, is $216.29 and right now they are offering free ground shipping on orders over $200.
    MexicanChip and Mendel Leisk like this.
  14. Mendel Leisk
    42,380
    My cost from Amayama, all in, is about 235 CDN, converts to ~175 USD. Do check it out for your loc's.
  15. Paul E. Highway
    210
    131
    Hawaii
    +1 on Amayama, though shipping times have gotten very slow due to COVID (they say).
  16. WolfpackBill
    WolfpackBill Senior Member
    349
    501
    Lexington, NC
    Code popped when I was driving 80mph. Gas pedal was disabled. It was a little scary as I was trying to merge 3 lanes to pull onto the shoulder. Water pump changed at 107,452 miles. I replaced it with Aisin WPT-190. It now has almost 164,000 miles and no codes.
  17. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    The ECU can detect that the waterpump has failed?
  18. WolfpackBill
    349
    501
    Lexington, NC
    I'd imagine so because I got the check engine code. I did speak with a seasoned mechanic about it and he said most likely there's an electrical spike and tripped the code but replacing it is good insurance.
    tvpierce likes this.
  19. tvpierce
    951
    883
    Maine
    2013 Prius v wagon
    Good to know. Thanks!
    Mine's at 180K miles. I guess I should plan to replace it.
  20. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,576
    2,605
    Taylors, SC
