P261B just came up but still drives
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by kobear18, Jul 20, 2020.
Tags:
  1. kobear18
    kobear18 Junior Member
    92
    23
    san francisco
    The new pump doesnt say made in japan u see they scratch it off? I already found the best seller on ebay 99.9% rating and got about 80k reviews. The part look brand new. I think it should be fine
  2. AzusaPrius
    AzusaPrius Senior Member
    2,184
    921
    Dont worry the new pump is toyota.
    They just do that to sell it cheaper.
    Also notice the gel like stuff in the old pump in the little triangle port?
    Thats what overheats the water pump.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    That's what I've seen before;).
    The swollen impeller is nothing new:cool:.
    That's your opportunity:).
    Good to sort that out (y).
    SFO likes this.
  4. kobear18
    92
    23
    san francisco
    Maybe bad news ..heavy white smoke initially after new pump. Turn heat n fan to max ...after 15min, not too heavy byt still low to medium white smoke...head gasket?
    Raytheeagle likes this.
  5. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Could be:cool:.
    How's the engine coolant level:whistle:?
    SFO likes this.
  6. kobear18
    92
    23
    san francisco
    It was thick but now it thin out ..maybe it just need to burn off those coolant....ya? Wishful thinking?
  7. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Could've gotten some strewn about the system:whistle:.
    I'd just monitor and see where it leads ;).
    Plan for the worst and hope for the best(y).
  8. ttou68
    ttou68 Active Member
    351
    211
    I couldn't help it to think it's such of waste that we couldn't just replace this part instead of a complete pump... tapatalk_1595734353868.jpeg
  9. Raytheeagle
    11,265
    15,520
    2019 Prius Prime
    Maybe @kobear18 can take some pics of the housing to see if it is scarred, but from the ones I have pulled off, they do show signs of impact:cool:.
    So best to do everything at once(y).
  10. kobear18
    92
    23
    san francisco
    i just came back after driving it for about 4.5 hours non-stop. I didn't notice white smoke from rear view mirror or at least not thick enough for me to see it. Good signs I hope. 2nd, no water pump lights came up. 3rd, no mis-fire light came up. However, it does rattle a lil bit every stop-&-go moment for just a few seconds. I drive locally only tonight and average speed is 22mph. I notice 1 more thing and after talking with my other friend who drives the same car. It could just be the aux battery going low. This may also be the cause it burn the water pump too. Its a old car and very high miles 250k. All the electrical need more energy than new car. It was my fault, I let the battery last too long maybe still not 100% sure if that was the cause yet. Base on Torque pro battery check, its still 14.1v during driving. But I still think it maybe the battery, 6 years and 7 months old battery. I got it Jan. 16th 2014 to today. I think I may go try a new battery on and see.
    the coolant lose maybe to leak. I lost a lot of coolant when I took the old water pump out. I of course filled it back up to full but the level drop a lil bit after driving maybe just the coolant going into the system. I will top it off tomorrow.
    #30 kobear18, Jul 26, 2020
  11. AzusaPrius
    2,184
    921
    Keep an eye on the coolant and remember to let the air out after each trip. Listen for any boiling sounds under the dashboard.
  12. kobear18
    92
    23
    san francisco
    ok just checked, it did lose some coolant. I also loosen the cap to let air out to release pressure. I will add some water mix to it tomorrow and keep monitoring
    #32 kobear18, Jul 26, 2020
  13. kobear18
    92
    23
    san francisco
    no boiling sound at all. No bubbles in coolant tank.
  14. AzusaPrius
    2,184
    921
    Use only toyota coolant 50/50 mix. Dont just put water in it.
  15. kobear18
    92
    23
    san francisco
    Ya i got concentrate toyota long life red/pink coolant. Ill need to mix it 50/50 with distill water.
  16. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    o_O
  17. ASRDogman
    ASRDogman Senior Member
    7,602
    3,915
    my my my Oh well.... People are going to do whatever they want....
  18. kobear18
    92
    23
    san francisco
    just checked the aux battery after 18 hours non-driving. Its 15.7V so I guess its not the aux battery's issue? So I got a land rover that has similar problem engine knocked and completely stalled while driving 2 years ago. I checked the aux battery n its no problem too. I still replaced that battery for it, it hasn't knock or stall problem ever since. Should I still get a new battery tomorrow when toyota part store open?
  19. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    Well it’s their car so they do what they want. Isn’t that one of your sayings here? :ROFLMAO:
    ASRDogman likes this.
  20. ASRDogman
    7,602
    3,915
    yyeesss.... it is! :)
