P261b OBD code. Coolant pump problem
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by IamPrius, Jan 1, 2021.
  1. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    At just over 242300 miles up popped the second check engine light my car has had, this time code P261b, means there is a problem with the coolant pump, the wiring or a relay. I checked the wires, no fraying or loose connections. I did not check the relays. I did notice the coolant was rather low, like to the bottom of the reservoir. I used the Torque app to clear the code to see if it would reappear. It did the next day. As I was driving around the coolant temp never got above 195 F. When I got home I did more sleuthing on the 'net. One article I read stated that if the coolant level is low it could draw air into the system and cause the code. So I bought the proper coolant and filled the reservoir to the proper level. It has been eight days now and the code has not reappeared and the coolant temp does not get above 195 F. Seems I solved that problem, but now I wonder why the coolant was low.
    #1 IamPrius, Jan 1, 2021
    amos and krmcg like this.
  2. jdenenberg
    jdenenberg EE Professor
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When was the last time that your coolant was drained and refilled? When my dealer did that job, they failed to completely eliminate all the air in the system. Driving my 2004 Prius a while cleared out the air and left me with a low coolant level.
    JeffD
  3. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    Have not done the coolant changes yet.
  4. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
    It was due at 100k miles and again every 50k miles thereafter.
    JeffD
  5. ChapmanF
    18,855
    Is this post about the 2016 shown in your profile?
  6. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    Of course. If it wasn't I would state that.
    amos likes this.
  7. Mendel Leisk
    42,144
    What's the consensus on the water pump here: preemptively replace every 100K miles? Or not soon thereafter? Thermostat too? @Raytheeagle ?
    Too many questions, lol.
    amos likes this.
  8. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    Well, I have 2432xx miles and have not replaced the water pump or the inverter. If it ain't broke, don't fix it.
    amos, alanclarkeau and Mendel Leisk like this.
  9. jdenenberg
    3,960
    1,956
    Trumbull, CT
    2020 Prius
    LE AWD-e
  10. Mendel Leisk
    42,144
    Or the coolant?? :eek:
  11. ChapmanF
    18,855
    Confirmation is good. You'd be surprised how many posts are from people having more than one car and neglecting to specify which. 242k is a pile of miles for a 2016.
    amos and Tande like this.
  12. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    I talked to the service manager at Toyota about it. Says they see cars all the time with higher mileage and/or older than mine with the original coolant and no problems at all.
    That does not mean I will not ever change mine out. Since I just bought a gallon I feel I will be doing mine soon.
  13. AzusaPrius
    AzusaPrius Senior Member
    2,249
    939
  14. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    Maybe it is, maybe it isn't. I'll change it when it goes bad.
    amos likes this.
  15. ChapmanF
    18,855
    My calendar/mileage date for the coolant would have been last year, but I had a bunch going on at the time so I dipped a test strip in and it came out fine so I spent the time on other things. When the weather warms up again I suppose I'll dip another strip, or just go ahead and change it.
    The pumps do seem to have an awkward failure mode possible, where the impeller comes apart and then the pump rotates easily without moving coolant. In 2010 there was a trouble code for pump RPM too low (that's what P261B is), but none for RPM too high, which is what happens when the impeller is busted. So in a 2010 you could have your pump thoroughly busted, not cooling your engine, and get no trouble code to tell you that.
    Apparently a code for RPM too high was added in 2011 (P148F). I would (nice person)-u-me that a 2016 has both codes, but it would be better to check the manual.
    What puzzles me in this thread is how a low-coolant situation could have led to a P261B, as the first post suggests. I would expect, if anything, a P148F if there was such low coolant the pump was slugging air.
    I have one nutty speculation that I have not yet had any time to test. In another post where the impeller busted, the Techstream-reported pump RPM was somewhere in the low 6,000s (I think full speed is normally 3,000-something when the pump is really pumping). It was a 2010, so no P148F code, so no trouble code at all logged, at least for low-6,000 RPMs.
    The possibility I'm wondering about (again, I've not tested this at all) is whether the ECM's pump-RPM scaling allows the RPM to wrap back to "zero" above some maximum RPM, such as, let's just guess, 6,553.5. That might allow, in some cases, an over-revving pump to set the under-revving trouble code.
    Still, in any car that has the tailor-made-for-over-revving P148F code, I would expect that one to show up first....
    amos likes this.
  16. Mendel Leisk
    42,144
    Low coolant and 242k miles: ever cleaned the Exhaust Gas Recirculation and Intake Manifold?
  17. AzusaPrius
    2,249
    939
    So once you get that code P261B
    It is time to change it out, trust me.
    The reason for low coolant is because it is turning to vapor in pockets because the pump is not circulating the coolant as it should.
    Hence low coolant and you will still get the code again.
    You will not like the outcome of total shut down when it completely fails.
  18. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    That's generally my philosophy too, but at 240,000 miles some maintenance if you want the vehicle to last much longer is in order, especially since replacing the coolant pump is not that difficult or expensive.
  19. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    Had not thought about hot spots. 8 days and counting so far w/out any codes. Temp does not get above 195 F and cools off pretty good when coasting.
  20. IamPrius
    IamPrius Member
    37
    29
    Lakehills, Tx
    No.
    amos and Mendel Leisk like this.
