P261b OBD code. Coolant pump problem
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by IamPrius, Jan 1, 2021.
  1. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
    This is a magnetically driven water pump, so it is pricier than the belt driven models;).
    But at 240+k miles, I'd invest in a new one(y).
    amos likes this.
  2. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    Glad you got up to 242k miles, without too much issue. Hopefully the code doesn't come back. Obviously keep an eye on your temps in case it does happen to fail which you seem to do. Doubt only a few guys happen to have over 200k miles on theirs this early. How about the other high mileage forums, does anyone else have water pump issues with their Prius from earlier generations?
    amos and Raytheeagle like this.
  3. Raytheeagle
    11,266
    15,520
    2019 Prius Prime
    I swapped the original water pump out on our old 2010 when it has 180k miles on it;).
    When I did, I found resistance in the impeller to turn:cool:.
    So when our 2019 Prime gets to around that mileage, guess what I'll be doing:whistle:.
    Life favors the prepared and the preventatively maintained (y).
    amos and robsnyder20 like this.
  4. thomassster
    thomassster Member
    239
    83
    Colorado, US
    2019 Prius
    XLE AWD-e
    The Gen2 had a mechanical belt ran water pump whereas Gen3 switched to an electrical one similar to the Gen4. The Gen2 went bad well before 100k miles. The Gen4 is probably similar to the Gen3 which many have gotten more than 100k miles, but it still goes bad. 200k miles sounds likes you got far with it.
    amos likes this.
