p261b, stop and go, power cycle rapid temp drop, triangle, coolant pump
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ben Schneider, Feb 24, 2019.
  1. Ben Schneider
    Ben Schneider Junior Member
    central florida
    i tightened it up again - am assuming i somehow need to recharge it ?
  2. Ben Schneider
    central florida
    again appreciating all your advice, ty
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Recharging you’ll need the right equipment to do so;).
    Not always available to the diy types so you’ll need to seek out a ac guy:cool:.
    Just make sure that they don’t have the incorrect oil in it(y).
  4. Ben Schneider
    central florida
    Appreciated... What kind of oil please
  5. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Worth searching around here, but I believe the ND-11 type is what you want and avoid the PAG oil;).
    You could try to add the refrigerant without the oil, but search around before doing a thing as the compressor isn’t cheap. If it were me, I’d drop the $20 for a two day subscription to techinfo.toyota.com and get all the right info:).
    Good luck and keep us posted (y).
  6. Ben Schneider
    central florida
    Just finished and got the hybrid warning, plus 261b 102 and 113
  7. Ben Schneider
    central florida
  8. Ben Schneider
    central florida
    driving now seems robust like it has not been in at least a few years and noticing temp goes up to 195.8 and hovers there, peaked a little higher on a hill and then went down to 190ish. though have seen it lower while driving. only a couple hundred miles so far.
