P261C engine coolant pump b control circuit ow, what does this code mean
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Aftab Ak, Nov 8, 2018.
  1. Aftab Ak
    Aftab Ak Junior Member
    46
    Pakistan
    I got p261c error code what does it mean, my engine light suddenly comes on and a warning light, car is prius 2011, please help
    52,855
    not sure that is a correct code, are you using tech stream?
    it could be that you need to replace the 3 way coolant control valve
  3. Aftab Ak
    46
    Pakistan
    not sure but someone told me to replace water pump, a warning along with engine light is on but the car drives good and suddenly some other lights come on as well and the car stops, then I restart the car and the car drives again with the engine light and warning light on, don't know what to do
    52,855
    check the inverter fluid reservoir with the car in ready. there should be movement in the fluid
  5. Aftab Ak
    46
    Pakistan
    yes dude there is moment in the inverter fluid
  6. Aftab Ak
    46
    Pakistan
  7. Patrick Wong
    18,210
    6,517
    The "someone" is correct. Stop driving the car. Replace the electric engine coolant pump.
    m.wynn and Raytheeagle like this.
  8. Aftab Ak
    46
    Pakistan
    hmmmm okay, can you please share it's picture I mean electric engine coolant pump
  9. Patrick Wong
    18,210
    6,517
    Raytheeagle and m.wynn like this.
  10. m.wynn
    m.wynn Senior Member
    684
    1,230
    Queensbury, NY
    It's not a bad idea to add the thermostat to this job. It's positioned directly opposite the engine casting where the water pump mounts and only adds 35 USD to the job:
    2011 TOYOTA PRIUS Water inlet sub-assy, w/thermostat. Inlet sub-assy, wate - 1603137010 | Toyota Parts Overstock
    I did a preemptive engine water pump replacement on my late, great 2010, using the Aisin WPT-190. It is indeed the oem pump, with the words Toyota and Aisin actually ground off. You can view the grindings in this pic and Youtube video:
    Patrick Wong and Raytheeagle like this.
  11. ASRDogman
    ASRDogman Senior Member
    8,066
    4,086
    It's always best to replace the thermostat when you replace the water pump. And to back flush the system.
    It really can't hurt.
  12. Nino nikki
    Nino nikki New Member
    Los Angeles
    P261b is engine water pump failure
    P261c is no power to pump. Check fuse first second check connection
    If you have p261b do the work yourself. It's pretty easy and save a lot of money. Buy oem part on eBay/Amazon. Check YouTube for installation guide.
  13. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Just got this today when I was on my way home. Going to check to see if the cable has disconnected or the water pump has seized.
    Ordered a new pump just now just in case.
    EDIT: I replaced the engine water pump. could this be the inverter water pump?
    #13 adrtho4, Mar 14, 2026
  14. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    The description of code P261C is "Short in Coolant Pump "B" Control Circuit "
    Possible trouble areas are:
    - Short in water pump assembly circuit
    - Water pump assembly
    - ECM
    adrtho4 likes this.
  15. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Coolant Pump B, that's the inverter.
    Well have one on order.
  16. Brian1954
    2,686
    1,073
    Code P261B and P261C are for the engine water pump, not the inverter pump.
  17. ChapmanF
    19,025
    Says who? :)
    P2 codes have descriptions that are standardized by SAE; when there are P2 codes that pertain to what Toyota wants a code for, they use the ones SAE defined. Per SAE, all of the P261{B,C,D} codes pertain to a "coolant pump B", and Toyota has used those codes in the engine control module to report problems with the engine coolant pump.
    The detection condition for P261C is "Water pump output voltage is less than specified value while the water pump assembly is operating (1 trip detection logic)", and interpreting that sentence requires thinking about whether a water pump output voltage is a thing and, if so, which circuit carries it.
    You might at first think the pump's RPM feedback signal might be an output voltage, but it's really a pulse train, produced by the water pump pulling down a voltage supplied by the ECM. The how-fast-to-go signal from the ECM to the pump is also a pulse train, that one produced by the ECM pulling down an output voltage supplied by the pump. More on how those circuits work in this thread.
  18. Brian1954
    2,686
    1,073
    I one of your earlier threads, I see that you did a head gasket replacement last summer and you replaced the engine water pump. What pump did you buy, and is it still the one in the engine?
    Attached is the 2011 Prius Toyota service manual for the P261C code. Follow the procedure to determine what the problem is.
    #18 Brian1954, Mar 15, 2026
  19. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    Yes, I replaced the engine water pump and the thermostat. I bough the AISIN-WPT-90
    It was working since then. I have to replace that again?
  20. adrtho4
    adrtho4 Member
    71
    26
    Houston, TX
    I got the check hybrid message when I was pulling into my neighborhood yesterday. All I can say is that I ordered a Lenovo Thinkpad T460 from ebay so I can load Techstream and really diag this thing. I'm getting conflicting info that this is the inverter water pump, or the engine waterpump.
    I may just say screw it and replace both. Sucks because I heard the AISIN was really good but it's been working since July of last year. Seems far too soon to replace it.
