P3000 p3009 c1256 after 12v battery change
Discussion in 'Generation 1 Prius Discussion' started by Scott quinn, Jul 25, 2018.
  1. Scott quinn
    Scott quinn Junior Member
    New bern nc
    2001 Prius
    I
    I have aGood running 2001 Toyota Prius. After changing 12 V battery, I got Coach P 3000, P 3009, C 1259. I don’t know what happened. Any suggestions?
  2. KarenA
    KarenA Junior Member
    34
    new york
    2003 Prius
    the same thing just happened to me, without the C1259. Were you able to find out what had happened?
  3. dansiantamour
    dansiantamour New Member
    Clawson
    Same. 1259 and a few others. I changed the 12 volt and am eliminating possibilities. Seems like I get a new code every time I touch this car. Good luck.
  4. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    Did you pull the traction battery disconnect before disconnecting and reconnecting the 12v battery? If not, that could be your issue. Did you clear them, did they come back?
  5. Scott quinn
    New bern nc
    2001 Prius
    I
    I did not disconnect the traction battery. I have cleared the codes, and they come back.
