  1. BuckeyePrius
    BuckeyePrius Junior Member
    What do you make if this?
    Screenshot from Dr Prius.
  2. TMR-JWAP
    TMR-JWAP Senior Member
    6,228
    5,912
    Columbia, SC
    Crazy voltage readings like that are usually indicative of bad connections on the HV battery module voltage sensing tabs or significant corrosion issues at the wire harness plug where it connects to the battery ecu. I would guess your problem probably lies in the second area.
    Is this a virgin, untouched original HV battery or are these readings following a DIY repair/rebuild?
    Give us the full story and we can provide much better assistance.
  3. BuckeyePrius
    Previous owner stated it was running well but had "some yellow" indicator light on. They had recently replaced the 12 volt battery. Car went into "safe mode" and the ICE wouldn't restart. I'm assuming bad wires at the traction battery due to the p3030 code. Just wondering if the every other extreme "bad" block indicates three bad blocks, or three bad wires. Thanks for the input.
  4. TMR-JWAP
    6,228
    5,912
    Columbia, SC
    I think some crazy sob mentioned this earlier....
    which would be......
    You may be getting ready to have a significant event at the connector where the voltage sensor harness plugs into the ecu.
    SFO likes this.
  5. BuckeyePrius
    Thanks again, I was attempting to fill in some of the blanks as requested. We will look at the connections first when it comes apart on Monday.
  6. TMR-JWAP
    6,228
    5,912
    Columbia, SC
    Blocks 2-7 most likely fall under the previously mentioned issue. For failed modules, I would be more concerned about block 10. It's ~1.3 volts lower than the other "normal" blocks. Indicative of a failed 1.2 volt cell inside one of the modules....
    SFO likes this.
