P3004-131 Need Help " 2009 "
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MackD, Oct 19, 2019.
  1. MackD
    MackD New Member
    houston
    Help im getting P3004-131.
    No other codes stored in the hybrid system or the hybrid battery system.
    I checked all the easy stuff.
    I checked every fuse in the car front to back including the safety plug "nothing is blown".
    I checked all the connections in the battery and cables connected to the battery "nothing was loose".
    I checked the the system main resistor.
    What should i check next?
    Im pretty sure i have to remove the relay #1 #2 and #3 to check them but im not sure.
    P3004 Power Cable Malfunction 131 "Impossible to drive"
    P3004-131 Power Cable Malfunction High voltage fuse has blown out, service plug grip is disconnected or limiter resistance is cut off
    - HV battery system - System main resistor - No. 1 system main relay - No. 3 system main relay - Main battery cable - No. 2 main battery cable - Frame wire - Inverter with converter assembly - HV control ECU
  2. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    maleko and Raytheeagle like this.
  3. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Here's the link I picked for the code.
    https://www.dtcdecode.com/Toyota/P3004-131
    looks like it's time to dig (grammar check)? into the high voltage documentation
    attention to the warnings - shorts around that stuff can be serious
    #3 vvillovv, Oct 29, 2020
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,110
    2,011
    NJ-USA
    Ummmm, this thread is just over a year old?
    vvillovv and SFO like this.
  5. Scott Caputo
    Scott Caputo Junior Member
    39
    Los Angeles
    I got this code and was wondering where the junction fuse block is located. I haven’t made any attempt to diagnose the sour yet, but I have a parts car that is going to be leaving soon and I thought I could at least grab this part first.
  6. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Should be right above the driver side front wheel.
    sholz likes this.
  7. Scott Caputo
    39
    Los Angeles
    I did some trouble shooting with the manual and figured out the the Hybrid drive ECU was bad. Is there any reprogramming that needs to be done to the one I’m replacing it with?
  8. mr_guy_mann
    4,110
    2,011
    NJ-USA
    You need Techstream (or equivalent) in order to initialize the HC ecu (gotta do a "handshake" between the HC ecu and the certification ecu).
