P3004 & U164 - Urgent Help needed
Discussion in 'Prius v Technical Discussion' started by Maple50175, Apr 23, 2024.
  1. Maple50175
    Maple50175 Junior Member
    MA
    So this 12 prius was at dealer, Was diagnosed and had these 2 codes
    P3004 High voltage Power Source
    U164 Comm error from A/C ecu to HV ecu.
    I replaced the Inverter as they said it was bad. Still the same 2 codes come up. Got another inverter same codes
    Fuses are good.
    Now when IG is on. The radiator fan goes high speed. Typically when this has happened on other cars it was a bad ECU or a plug not fully plugged in.
    Car was driving fine. Went to part it overnight then it would not start in AM. Shows check hybrid system and check pcs system.
    Any help would be appricated!
  2. Tim Jones
    Tim Jones Senior Member
    1,762
    569
    SE Texas
    2011 Nissan LEAF
    Toyota is supposed to replace the inverter
