P3006 now what?
Discussion in 'Generation 1 Prius Discussion' started by Cofi, Sep 25, 2017.
  1. Cofi
    Cofi Junior Member
    57
    Co springs co
    2001 Prius
    I
    I’m thinking about rebuilding the hv battery myself to cut down on cost is this still a viable option? Where’s the best place to buy individual cells?
  2. greasemonkey007
    greasemonkey007 Active Member
    287
    107
    South Central Arkansas
    If you have the original 1st gen battery, you'll probably want to buy a couple of newer packs, either 2nd or 3rd gen, to rebuild with. The 1st gen modules will probably not be any good. Or you can buy a new one at Toyota for about $2000.
  3. FireFighterHill
    221
    92
    Orlando/Clermont
    2003 Prius
    I
    You can't mix different gen cells, as they are slightly different sizes. Find a local prius parts recycler, look through Craigslist
    SM-G950U ?
  4. greasemonkey007
    287
    107
    1st gen won't mix and match with newer ones, but you can replace all 38 modules
  5. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    735
    Boulder Hybids, Boulder, CO
    Original (2001-2003 build date) Gen1 modules are all pretty much garbage or soon will be garbage.
    If you like the car, best option is new gen1 dealer battery for around $2000 if you can buy wholesale. You can also buy used Gen2 modules, but it won't be as good as a new battery and you need 38 modules for a gen1 pack. You are rolling the dice with aftermarket "rebuilt" packs.
    Junkyard packs are also a waste of time. I had a customer recently buy 3 junkyard gen1 packs over the internet. All were bad even though the selling yards said they were good...they don't have a way to test them LOL!
    COFI, if you want no headaches we charge $2500 installed for a brand new Gen1 Prius pack at our Boulder Shop. Sales tax additional, core required. http://www.BoulderHC.com
    ammdb and WHCSC like this.
  6. AlexY
    AlexY Member
    163
    45
    UK
    Sorry guys, I didn't knew it and did it.
