P3009 battery Frankenstein project
Discussion in 'Generation 1 Prius Discussion' started by oldnoah, Oct 17, 2010.
  1. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Here's a page on the MRC "Superbrain" 989. Both Bob and I have this model. You can program it to a variety of different kinds of cells (nicd NiMH...) and tell it how many cells it is charging at a time. Also, you can do charge cycling, by telling it the minimum voltage (per cell) it should discharge to, and it automatically determines how much to charge based on a "DV" number which is in millivolts per cell. I generally have it do 3 cycles, in order to get the final charge and discharge numbers that I'm using to determine these modules charge characteristics. You can also tell it how many milliamps to charge before cutting off, and you can use it as a power supply.
    MRC - BATTERY CHARGERS Series - SUPER BRAIN 989, Item: RB989, RC PRODUCTS/BATTERY CHARGERS
    Oh, and yes, I have used it to charge about 20 modules at the same time by paralleling them. The charger thinks it's charging 6 cells, and doesn't seem to notice the difference.
  2. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Interesting, concerning "I have used it to charge about 20 modules at the same time by paralleling them. The charger thinks it's charging 6 cells, and doesn't seem to notice the difference." I would be careful here as the current capabilities of 20 modules in parallel would probably be beyond the capabilities of the output circuit as far as surge current characteristics when first connecting it. But if you're having good luck they must have designed it well. Will definitely check it out, thanks Tom
  3. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Here's my plan for assembly. Red numbers indicate modules taken from the newer p3009 battery, Black is from the older battery with some bad cells (uneven state of charge)
    Module replacements were selected based on the greatest discharge during cycle testing. The selected modules were discharged to ~7.69 volts each, and then assembled into a parallel battery pack.
    The pack was then charged and discharged several times, and then allowed to sit for a couple of hours to equalize voltages between the modules. Then the parallel connections were taken off, and the voltages were allowed to settle for several hours, at which point the voltages in the following table were recorded.
    Modules were paired into blocks so that the voltage of each module adds together to create blocks with relatively equal voltages.
    Column 1 Column 2 Column 3 Column 4 Column 5 Column 6
    0 Block # Module # Voltage Module # Voltage Block voltage[/FONT]
    1 1 19 8.23 31 8.19 [/COLOR]16.42[/FONT]
    2 2 20 8.23 35 8.2 [/COLOR]16.43[/FONT]
    3 3 10 8.23 34 8.2 [/COLOR]16.43[/FONT]
    4 4 24 8.23 33 8.2 [/COLOR]16.43[/FONT]
    5 5 7 8.23 32 8.2 [/COLOR]16.43[/FONT]
    6 6 9 8.23 27 8.2 [/COLOR]16.43[/FONT]
    7 7 12 8.23 23 8.2 [/COLOR]16.43[/FONT]
    8 8 14 8.23 17 8.2 [/COLOR]16.43[/FONT]
    9 9 14 8.23 5 8.2 [/COLOR]16.43[/FONT]
    10 10 34 8.23 38 8.21 [/COLOR]16.44[/FONT]
    11 11 1 8.22 36 8.21 [/COLOR]16.43[/FONT]
    12 12 22 8.22 30 8.21 [/COLOR]16.43[/FONT]
    13 13 4 8.22 29 8.21 [/COLOR]16.43[/FONT]
    14 14 16 8.22 28 8.21 [/COLOR]16.43[/FONT]
    15 15 26 8.22 8 8.21 [/COLOR]16.43[/FONT]
    16 16 36 8.22 7 8.21 [/COLOR]16.43[/FONT]
    17 17 1 8.22 6 8.21 [/COLOR]16.43[/FONT]
    18 18 37 8.22 4 8.21 [/COLOR]16.43[/FONT]
    19 19 2 8.21 3 8.21 [/COLOR]16.42[/FONT]
    The parallel connections were then remade, and the pack will sit overnight to maintain the voltage balance before assembly and installation tomorrow.
  4. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    For some reason some of the red numbers changed to black while being transferred from Excel to the table tag format. The only modules above that are from the old battery are 1,4,7,9,14,34, and 36 in the left column.
  5. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    It's aliiiiive!
  6. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    0 As installed After test drive
    1 SOC 59.5 SOC 73.0
    2 Block Voltage Voltage
    3 1 16.2 16.9
    4 2 16.1 16.8
    5 3 16.2 16.8
    6 4 16.1 16.8
    7 5 16.1 16.8
    8 6 16.2 16.9
    9 7 16.1 16.8
    10 8 16.2 16.9
    11 9 16.2 16.9
    12 10 16.1 16.9
    13 11 16.2 16.9
    14 12 16.3 16.9
    15 13 16.2 16.9
    16 14 16.2 16.9
    17 15 16.3 16.9
    18 16 16.4 17
    19 17 16.4 17
    20 18 16.4 17
    21 19 16.3 17
  7. bwilson4web
    16,513
    Awesome! The maximum difference is 0.2 V., very similar to mine! Excellent!
    More important, you've cleaned out the leaked electrolyte which time will tell if it ends the P3009 code.
    Looking at the data, I'm wondering about the calibration of blocks 16-17 and blocks 2-5?
  8. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    What about it?
  9. bwilson4web
    16,513
    We assume the battery controller is accurately measuring the block voltages. This is one area where an independent measurement might make sense . . . to verify the accuracy.
    The other option is Vincent's suggestion to remove the decimal point for an extra digit.
  10. w2co
    w2co Member
    366
    81
    Longmont, CO.
  11. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    I drove it on my business trip today, about 250 miles since I installed it. SOC has settled into 65-68 and voltages are within 0.1 except for 1 module.
    I have two MRC's, and I left the modules in the assembled battery for compression, but removed the buss bars to access the terminals. Most of the time I charged 2 modules at a time, using setting of 1.5 Amp charge/discharge, 5 minutes rest between charges, and 5 mV peak voltage (although I don't quite understand what that means). I cycled each module 3 times to get the maximum mAhr discharge/charge numbers, and used these to choose which modules to select for the final pack.
    I only parallel charged the whole pack in an attempt to balance the charge before assembling the battery. I had tried it earlier with the old battery to see if it was possible, and then again with the 38 modules that I had chosen for the final assembly. I charged and discharged it several times to get the charges even. Seems to have worked.
    I've got way too much time into it, but I learned a lot.
    Now I've got an extra battery case, ECU, some possibly usable modules and some really dead modules that need recycling. And two chargers that I doubt I'll have much use for until the next time I decide to do something crazy like this. What to do with it all?
  12. w2co
    w2co Member
    366
    81
    Longmont, CO.
    Sounds good thanks. Perhaps you should hold on to those "possibly usable modules" just in case some in the pack go south. If they're going to I would think it would be within a week or so. But like mentioned b4, if you drive it everyday now for a few weeks they'll settle in for the real avg soc.
    Congrats! Great job.
  13. bwilson4web
    16,513
    Wait 30 days keep the good modules charged. After 30 days:
    • Ebay NHW11 rebuild kit - the good modules, MRC 989, case and electronics
    • Contact Re-InVolt and see if they are interested in the electronics and case
    • Carefully, disassemble the bad modules and investigate the terminals, pressure relief valve, and keep the plastic cases (I'm interested.) The battery guts are metal hydride and nickel. See if any metal dealers are interested.
    • See if Batteries Plus will take the bad module left-overs for recycling
    • Hillbilly plug-in hybrid - actually Orange4boy inspired the idea of a 14-16 V battery to offload the auxilary battery by charging the NiMH battery from the grid to run the 12 V system
    • Any interest in rehydration experiments?
    You have options. Best of all, you have unusual skills and experience. You might consider going to "Hybrid Fest" next summer.
  14. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Well, this weekend it took us to D.C. for the rally, and while I sat in the passenger seat I programmed the scanguage for the block resistances. According to the codes from the scangauge thread, I guess these measurements are in milliohms. But I don't have any basis for comparison. What are good numbers here?
    Column 1 Column 2
    0 Block Resistance
    1 1 21
    2 2 21
    3 3 19
    4 4 20
    5 5 21
    6 6 21
    7 7 20
    8 8 21
    9 9 20
    10 10 20
    11 11 20
    12 12 20
    13 13 20
    14 14 20
    15 15 20
    16 16 20
    17 17 20
    18 18 20
    19 19 20
    Also I looked back at the reject modules, and found that the heat pattern from Bob's photos is considerably more evident in photographs than it is to the eye. I don't know what the "still good" modules look like, because they're assembled into a parallel block and on the charger, but this is module 8 and 11 which were among the worst of the modules from the old battery.
  15. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Yes, they are in mΩ. Here are my values:
    0 Block Resistance Voltage
    1 1 22 15.30
    2 2 21 15.23
    3 3 21 15.23
    4 4 21 15.24
    5 5 22 15.23
    6 6 21 15.25
    7 7 21 15.24
    8 8 21 15.22
    9 9 21 15.22
    10 10 20 15.23
    11 11 21 15.25
    12 12 22 15.20
    13 13 21 15.22
    14 14 21 15.24
    15 15 20 15.29
    16 16 21 15.25
    17 17 20 15.25
    18 18 20 15.31
    19 19 21 15.32
    The ideal case would be all having the same resistances and voltages. As the cells age, their resistance tends to become higher (see below comparison of NHW10 & NHW11 HV Batteries). NHW11 is rectangular or prismatic type.
  16. adric22
    adric22 Ev and Hybrid Enthusiast
    642
    146
    Fort Worth, TX
    They will. I once disposed of an entire 38 modules of an NWH11 Prius pack. Granted, I just brought them the modules, not the whole battery pack. They said as long as they were NiMh, they'd take them.
  17. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    From what I've seen, the resistance numbers don't change much. Are the voltages relevent? Unfortunately with the scangauge I have to reprogram the xgauges to get the voltages back, so I can't get resistance and voltage from the same time period.
    Also, looks like my numbers are similar, maybe a little better than yours. Does anyone have data on a younger battery? Or an older one?
  18. vincent1449p
    894
    332
    Singapore
    I don't see much change either. Maybe I 've only use scangauge for a few months, long term monitoring may see changes.
    I list them out to show they are not related to resistance values.
    One trick is to use CMNDS. Since the resistance don't change much, I used 5 slots in CMNDS to store resistance. Each CMNDS can display 4 resistance at a time. For voltages, I use XGAUGE as they change quite frequently.
  19. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    I'm bumping this thread, partly because I got a message from Joekingiam asking how to balance a battery, and partly just to give an update on my car to anyone who's interested.
    The car is still running fine, with the highest voltage module pair generally reading about .2 or .3 volts higher than the lowest voltage module pair. My fuel mileage actually is about 1 or 2 mpg better than it was before the battery rebuild. Other than that I changed the inverter coolant and pump. I need to do the struts and I will need 2 new tires when I take off the snows. Anyone have a preference for summer tires on a 1st gen?
  20. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Re: P3009 battery Frankenstein project. Coming up: 1 Year!
    Bumping the thread again, since I'm coming up on a year since the battery has been rebuilt. It's still running great. ScanGauge still shows about .2 to .3 volts difference between the highest and lowest modules.
    I haven't hung around here at priuschat since I haven't had any problems with the car, which is now coming up on 180,000 miles.
    I did get a recall notice from Toyota on some bolts in the steering rack, and took it in to get the recall done. They said that since they couldn't get the rack to zero, they couldn't do the recall without replacing the whole rack. So they gave me a brand new rack. Can't argue with that on a car this old.
