P3009 battery Frankenstein project
Discussion in 'Generation 1 Prius Discussion' started by oldnoah, Oct 17, 2010.
  1. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Due to Special Service Campaign 40G sealant application, did you have to "gently" pry the bus away from the terminals? In my 01 the bus is completely stuck to the cell modules. What did you use to clean the sealant material off the bus and terminals?
  2. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    My 01 battery with 111,200 miles, codes P3000, P3006, P3012, P3016, P3022, P3024 has the following voltage read (MFD indicated full charge prior to dis-assembly)...
    Module Volts
    1. 7.97
    2-8. 7.96
    9-11. 7.95
    12. 6.50
    13-23. 7.95
    24. 6.51
    25-27. 7.95
    28-33. 7.96
    34-37. 7.97
    38. 7.98
    Without knowing true SOC can I assume 12 and 24 are shot and others are fairly weak?
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi tnt01prius,
    Yes, module 12 & 24 are more than 1.2V difference than the lowest voltage 7.95V. There are 6 cells in a module so one of the cells has shorted.
    The DTCs also indicate Block 2 (Module 3 & 4) and Block 14 (Module 27 & 28) had been logged as uneven voltages. The voltage you measured seems OK now but it could possibly drop when it is under load. Another possibility is that there might be KOH leakage from the terminals. You can check this by measuring the voltage from the terminals to the base screw hole.
    Vincent
  4. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Yeah, I would replace 12 and 24. You can't really know the condition of the other modules without charge testing, but that's time consuming. Right now my attitude is that if I get a bad module I'm just going to replace it and get on with my life. You can literally spend a month charge testing (and that's if you have two chargers)
    Yes you have to pry the buss bars off gently. I cleaned the buss bars and plastic covers by soaking them overnight in mineral spirits, and then blowing the goo off with compressed air. It worked very well. I also sand blasted the buss bars to get down to clean copper for a good contact.
    I cleaned the modules by soaking them in vinegar to neutralize the KOH. Until you do this, be very careful about getting that stuff on you. Wear gloves, and safety goggles. Once it's been neutralized you can brush off the crud with a toothbrush, then rinse them in clean water and dry them completely.
    Also check the voltage sense wires carefully to make sure none are broken. They can have very small breaks that you can't see, so use an ohmmeter to check for continuity. You might want to clean them with vinegar also, and again, be sure to rinse them and dry them carefully.
    Vincent: I don't have the DTC list handy, does he have anything there that wouldn't be solved with a cleaned up battery?
  5. vincent1449p
    894
    332
    Singapore
    I believe modules replacement and cleaning most likely would solve his problem but my question is whether the terminals are leaking KOH. The reason for SSC-40G is to prevent this but after cleaning, most of the sealant may be washed off.
    Vincent
  6. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    When I did this project last year I cleaned off as much sealant as I could, and my impression was that it hadn't done anything to prevent leakage. But my battery has been running for over a year, and I haven't had any codes. Worst case scenario to me is that I might have to take it apart and clean it the next time it pops a P3009.
  7. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Thank you Vincent and Noah for sharing your experiences with the Gen 1 HV battery. It is good to know people are keeping the classics going after a decade. I would love to keep my 01 going, but I'm considering the thought of getting my 01 back together and then decide if it's time to move up to the more reliable Gen 2. We already own an 05 and am well pleased with it. Your inputs and others on PC have given me valuable insights to make informed choices and hopefully complete my own repairs safely. I'll be in the garage probably all day tomorrow :)
    May God and my classic treat me kindly.
  8. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,518
    38
    Santa Fe, NM
    I clean bus bars in hot pickle -- Sparex -- a solution of sodium bisulphate used in jewelry making to remove flux and oxidation. The wife keeps a Crockpot of the stuff going round the clock so it is convenient, but probably overkill.
    tnt, I think you have 36 perfectly good modules, and two bad ones. Now, something to look at are those 36 voltages just before you reinstall the battery. I had a battery surprise me the other day: one module had a normal reading when it came into the shop but dropped by 1.2V after sitting for a week, making it a discard.
  9. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Thanks. Hey, does anybody know how to decipher the code stamped on the top of a cell module, particularly does it indicate a production date? Here is an example: 29XF2A07950D. If a module's voltage falls below 7.2v from sitting idle, should it be discarded and replaced?
  10. vincent1449p
    894
    332
    Singapore
    http://priuschat.com/forums/generat...ybrid-battery-manufactured-4.html#post1169559
    http://autos.groups.yahoo.com/group/Prius_Technical_Stuff/message/38177?threaded=1&l=1
    If your modules are original, it should be close to the battery pack's date code.
    Vincent
    joedirte, tnt01prius and seilerts like this.
  11. seilerts
    3,326
    1,518
    38
    Santa Fe, NM
    All will fall below that if left long enough. With yours, since they are at 7.95V now, it would take several months, if not a year or more, before a good one would self-discharge below 7.2V. Mostly, if you find one below 7.2V before you put the battery back in, it is bad.
  12. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Bumping this thread because I had a module fail in the rebuilt battery. I thought people might be interested to know how long the rebuilt battery lasted. According to this thread I originally rebuilt the battery in October of 2010, and the car had about 170K on it. It is now March of 2014 and the car has 220K on it.
    In the weeks leading up to the p3006 code, I watched the scangauge as the voltages got rougher. I frequently saw the Vhi and Vlo voltages greater than 1.5 volts apart, but it's hard to tell with the scan gauge whether those readings actually occurred at the same time. Sometimes it was clear that the low voltage reading had been taken while the battery was under load, while the high voltage reading was taken while the battery was being charged.
    I also made note of which block of modules were reading low (blo) and found that although block 5 was the most chronically suspect, but it was usually blo while the battery was charging, while block 16 was blo while the battery was on load. As the hi and lo voltages got more erratic, block 16 spent more time as the lowest block, and block 5 only showed as lowest when the charging cycle got more pronounced. Finally, I saw the voltages greater than 1.2 volts apart while the engine was off (car was ready), and the dreaded red triangle still hadn't appeared. About 5 minutes later as I was driving the warning came up. The battery went into a charge cycle, brought the state of charge (soc) up to 89%, and the voltages stabilized at about .4 volts apart. I reset the code and continued driving. For a week. It flashed the code a couple of times during that week, but after a charge cycle, the voltages stabilized again and I could reset the code and keep driving. (Today is Sunday) This past Friday I was driving home, and the code flashed, so I reset it, and continued home. It flashed again. I reset it and continued. It never flashed again, but I could see the charge cycle go nuts. Sometimes it showed the soc at 34%, yet Vhi was 19.2 and Vlo was 18.8. Another time it showed 84% soc while the voltages were 13.8 and 13.2. Eventually I saw a 99% soc. with voltages in the 18V range, and still greater than 1.2V between bhi and blo. I figured it was time to take the battery out and fix it, even though it was still running, and hadn't coded for about 20 miles.
    I guess I was lucky that it was so cold. The battery temperature started the trip at about 24 deg, and ended at 58 deg.
    So I got the battery out and measured the voltages. Highest voltages (this is modules, now, not blocks) is 8.17 on modules 1 and 38. Two modules are at 8.10, and module 32 is 7.19. So that's my bad module. I could replace the 8.10 volt modules, but at this point my replacement modules are just as suspect as the rest of the pack. I've been holding them on a charger for the last 3 years, using the parallel arrangement that's discussed earlier in this thread. Every once in a while I take the pack apart and let the voltages decay, so I can see if any modules have failed. Several have, so they have been discarded. I also periodically run each module through a charge/discharge cycle and record the data, just so that when the battery in the car fails I will have a better idea of which module to use for a replacement.
    As luck would have it, I did this last month. So I've chosen my replacement module and I'm putting it back together now.
    Dxta, usnavystgc and bwilson4web like this.
  13. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    " I thought people might be interested to know how long the rebuilt battery lasted."
    I'm curious, did you state somewhere how the battery was "rebuilt"? Swapped a few modules, replaced all modules or installed a 3rd party rebuild?
  14. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    The thread you're reading describes the process. There was another thread called "battery autopsy" that described some of the earlier steps. But the "frankenstein" in this case refers to taking two dead batteries, testing the modules, balancing the modules state of charge, and then putting the whole thing back together.
  15. tnt01prius
    tnt01prius Member
    105
    Surprise, AZ
    Okay thanks. I didn't read all of it.
  16. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    I know this is an old thread. Are those chargers still available? Are they up for sale, just in case in future?
    Is this car still up and running today?
  17. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Yes. Chargers are commonly used in the RC hobby.
    AdvancedSearch Results | TowerHobbies.com
    They charge nearly any battery chemistry. Lead Acid, NIMH, NICD, LiPo, LiFe. (but check product info to be sure) Some are single bank, some dual, most expensive will do 4 at a time.
    You can also find these at your local hobby shop, or if you have an RC flying or RC car track nearby, pay it a visit. Probably one or two guys out there with an extra charger they might be willing to let go of on the cheap. Might also look at Hobby King. I bought a single bank charger there for about $50.00 I use it for my addiction to RC airplanes, but have used it to charge a lawnmower battery a couple times
  18. Dxta
    Dxta Senior Member
    1,941
    769
    Lagos
    Thanks for the replies. I live in Lagos, Nigeria. So, its kinda difficult getting those, over here.
  19. oldnoah
    oldnoah Member
    189
    56
    New York
    2001 Prius
    Yes, the car is still up and running, but the Frankenstein battery isn't. The car had about 170k miles on it when I rebuilt the battery, and it lasted a few years, until the car had, something like 210k miles on it. At that point, I still had modules I had been keeping on the charger, so I picked one and replaced the bad module, and put it back together again. It lasted several months before another module went bad, and I did it again. The next time a module went bad was only a month or so later, and I decided it wasn't worth it to keep taking the battery out of the car to change one module, so I bought a "remanufactured" battery for about $900 (not from ReInvolt, but I don't remember the company off the top of my head). That battery is still in the car, and the car is still running fine with 260k miles on it.
    I still have the MRC chargers.
    Dxta likes this.
