P3011 after replacing battery modules
Discussion in 'Gen 2 Prius Main Forum' started by magicBarry, Jun 14, 2020.
Tags:
  1. magicBarry
    magicBarry New Member
    Fishers, IN
    I just replace 3 modules on my 2005 Prius. Now it is giving me a P3011. I think the error is coming from the 3 modules that I just replaced. Is it possible that I am just getting the code while it balances out the cells? Otherwise I am out of ideas.
    52,380
    welcome!
    i'm not sure the car will balance the cells, you may have to do it
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    The blocks on the Gen 2 Prius start with Block 1 being the 2 modules furthest from the ecu section of the battery and Block 14 being the 2 modules closest to the ecu section. Quite often, the wrong module gets replaced if the person isn't familiar with the numbering sequence.
    P3011 would be Block 1 becomes weak. That would be the two modules furthest from the electronics section. Which ones did you replace?
  4. AzusaPrius
    AzusaPrius Senior Member
    2,232
    930
