P3012, Red Triangle, but all module voltages stable...
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by dpeverhart, May 28, 2014.
  1. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,095
    Columbia, SC
    Did you notice the voltage readings on the first 3 blocks? 12.8v, 330v 328v
    If #1 is correct, then there's definitely still an issue with one of those modules. The other 2 are obviously whacked and could be a torque setup error or the harness plug/ecu socket has some issues.
  2. thetorvic21
    thetorvic21 Junior Member
    north haledon
    Thanks again ill get an in-pound torque wrench what should the torque each one for the bars and the the two terminals be
    ill probably call you later today when would you be able to answer
  3. ericbecky
    ericbecky Hybrid Battery Hero
    4,452
    3,359
    Madison, Wisconsin
    Ha, Ha. That is hilarious.
    Did not see that. I was on mobile without my glasses.
    When people setup the gauges like that it is way too tiny for me unless I go grab my glasses.
    Kinda worries me if OP was not aware that that might be an obvious issue. :)
  4. LoveourPrius
    LoveourPrius Junior Member
    16
    Eric:
    Thanks for the great advice. I have the same P3012 code after replacing all the cells in my 2006 with cells from a 2011. I'll now re-check all of those battery post nuts, connectors and crimping.
    1) What should the torque be on the battery post nuts?
    2) Any suggestions on how to clean the connectors on the voltage sensing side of the battery?
    I cleaned all the copper plates in vinigae and sale and then sanded with a 400 grit paper but did not want to risk damaging the wiring on the volatge sensor side, so any suggestions or comments would be appreciated.
  5. ericbecky
    4,452
    3,359
    Madison, Wisconsin
    If the voltage sensing wires are bad enough to need cleaning, instead you could just by a new wire frame from Toyota parts department. Comes with new wires and bussbars.
  6. Mike Cregar
    Mike Cregar New Member
    Az
  7. Melissa Forman
    Melissa Forman New Member
    Ok so from what i was reading this kinda sounds like the same problem were having bought a brand new one from O'Reilly's spent about 1700 a few months back and now its throwing code p3012 and said replace hybrid batter pack system could there be something else wrong with the Prius causing the hybrid battery to be going bad?
  8. dolj
    dolj Senior Member
    8,645
    4,394
    Wellington, New Zealand
    What you bought was a second-hand battery from O'Reilly's and it is highly likely that it is not something else. Old batteries fail. You need to look at the warranty you received with the battery and find out how you make a claim.
