P3019
Discussion in 'Generation 1 Prius Discussion' started by aswresm, Sep 2, 2014.
  1. aswresm
    aswresm Junior Member
    50
    2002 Prius
    I
    P3019 = Battery block 9 becomes week.
    I am planning on replace the battery cell in my 2002 Prius....My question is .....How would you identify block 9 ?....Are blocks numbered?.....How many cells are per each block?...If each block has 2 cells ?then would I have to replace both cells?
    Answers would be greatly appreciated!!
    Thank you!!
    veelo likes this.
  2. Patrick Wong
    18,210
    6,517
    1. The best way is to use a voltmeter to measure the voltage of each of the 38 modules. You'll find that at least one of the 38 modules shows much lower voltage compared to the others.
    2. The blocks are not physically numbered. I believe the numbering starts from the traction battery ECU side of the traction battery.
    3. Two modules per block
    4. Actually, considering your battery is 12-13 years old, I suggest replacing all 38 modules unless your idea of fun and entertainment is to open up the battery case every few months to replace yet another module.
  3. bwilson4web
    16,523
    Please post the module position, #1 by the ECU, and voltages. That a middle module failed is consistent with a heat stress pattern we've seen in other batteries. But at a minimum, replace the modules on each side as they have been subject to heat stress from the failing module.
  4. ericbecky
    ericbecky Hybrid Battery Hero
    4,451
    3,359
    Madison, Wisconsin
    Battery case has numbering on it from ECU side.
    Each block has 2 modules. Although you will likely find one of the pair that is most likely the culprit.
    I sell modules in pairs, since although only one may be failing now, another may show up fairly soon. (As Patrick alluded to.)
    As long as it is still fun for you, you can keep replacing modules. But not everyone finds it an enjoyable hobby.
    chronon likes this.
  5. aswresm
    50
    2002 Prius
    I
  6. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Looks like I may be selling some of my current inventory of Gen 1 modules here locally.
    Let me know soon if you think you want any.
  7. JC91006
    16,936
    8,647
    Are all generation modules the same size?
  8. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    Not exactly.
  9. JC91006
    16,936
    8,647
    gen1 and gen2 can't be mixed right?
  10. ericbecky
    4,451
    3,359
    Madison, Wisconsin
    I wouldn't do it unless it were an emergency and temporary.
    bwilson4web likes this.
