1. mike_az_21
    mike_az_21 New Member
    26
    Arizona
    And, here we have it - my whole battery is pretty much garbage
    the first is mine
    The 2nd is my neighbor’s beat to garbage Prius
    What’s kinda funny is that mine looks near mint & his is completely destroyed
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,114
    2,012
    NJ-USA
    You can look at the freezeframe data (if any) that is stored - click on the snowflake icon next to the code. That should have battery block voltage values about the time it set the P3020.
    You can also monitor block voltages with Techstream while someone else drives. Or you can record data while driving (and review it later).
    All of which will likely confirm a faulty module. ie, drops by about 1.0-1.5V lower than others under discharge (heavy accel) and goes higher under charge (decel).
    mike_az_21 likes this.
  3. mike_az_21
    26
    Arizona
    But, yeah - looks like pretty much the whole bat is trash. . . It’s fine since I paid 700 bucks for the car & it still gets the best MPG out of all of our vehicles - still gets about 35mpg
    I’m hoping to find a wrecked one still running, so I can test it before I pull it
  4. mike_az_21
    26
    Arizona
    E50BE687-0E2B-4CA0-98A1-5D00BAD8E3BD.jpeg Back at it - again
    Just been driving the car 1/2 dismantled
    DrPrius readings completely changed about a week ago
    Keep driving it - it throws another code, now p3000
    I keep looking online, found some random page that pointed me to this harness
    Cut, it out the corroded wires & soldered them - readings completely changed again & now the car goes to 65%+ charge in a drive just around the block - and, now reads green
    Sure is nice & time consuming
  5. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Corrosion at that connector is common and results from cracks in the seam sealer around the tailgate opening in the body. Look around the TG lift ram body mounts, then go up toward the rain channels under black rubber strips on the roof. Little cracks that should be cleaned and resealed.
    I would expect a battery fan problem to set a P0A84 in the battery ecu. Dr Prius is handy but doesn't reliably pull codes from both the hybrid control ecu and battery ecu. (P3000 is the HC ecu saying "hey, battery ecu says it's got a problem, you should go over there and check it out.)
    Still sounds like the HV battery is weak - you need to look at voltages when accelerating hard (high discharge amps).
    You might want to read this thread that reviews several scantool apps and devices - some are fully capable of reading codes and data from all systems on a Gen2 Prius
    https://priuschat.com/index.php?posts/3290690
  6. mike_az_21
    26
    Arizona
    What should I look for?
    I’m not much into hammering on this car at all. The drive train has almost 290k, had all of its maintenance - but, still
    Tombukt2 likes this.
  7. mike_az_21
    26
    Arizona
    NVM - I just seen the post above my own
    it’s just so hard to spot & chase - all the voltages are all over the place
    and, it still hasn’t thrown the same code again
  8. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Well, you can use Dr Prius - it has the "VOLT DIFF" (voltage difference) data line. In general that should stay at or below 0.3V, if it goes higher than that for more than a few seconds (or goes crazy high - say over 1.0V) then the ecu will take notice and eventually set a code.
    If you have high voltage difference then you can pay attention to individual block voltage values to see which ones are going too low (or too high).
    On the android Dr Prius, you can hit the record button and it will save data while you drive as a .csv file ghat you can look at later.
  9. mike_az_21
    26
    Arizona
    Never seen a huge volt dif, and it reads normal - yet pops a p3000 code just out of nowhere
    Still gets amazing mpg
    But, my “mechanic” opinion said it was the battery right away - since the battery just stinks like a fried circuit board - and, it is the cells themselves that stink
  10. mr_guy_mann
    4,114
    2,012
    NJ-USA
    Certainly possible.
    Me, I would like to see what code is in the battery ecu (and any freezeframe data).
  11. mike_az_21
    26
    Arizona
    How do I pull up codes from the battery ECU? I’ll look into it since I still have the car. My mechanic guys Solus pulls up nothing - these are quite different than anything that’s internal combustion for sure
  12. mike_az_21
    26
    Arizona
    Decided to pay the 14 Bucks for the “Pro” version of DrPrius - y not
    Full battery test said cell 10 is a “suspected problem block”
    And, the life expectancy test said 45-46%
  13. mr_guy_mann
    4,114
    2,012
    NJ-USA
    You use one of the scantools from the link in post #25 - specifically one of the tools capable of scanning all systems. It's up to you to decide if you need functions like reading freezeframe data and INF codes, or having bidirectional controls.
    If you read the entire scantool review thread, I specifically mention Dr Prius pulling P3000 (from hybrid control ecu) but not have any codes from HV battery ecu. (I guess it's a glitch in the app?) This must be what's going on with your car.
  14. JohnPrius3005
    JohnPrius3005 Active Member
    423
    235
    California and Hawaii
    Suggest you get techstream, bootleg version on eBay. It's not hard to set up, and has all the functions you'll need
  15. mike_az_21
    26
    Arizona
    Downloaded ELM on my iPhone - yup, still the 10th Cell
  16. mike_az_21
    26
    Arizona
    So, in theory - is worth swapping just the 10th pair of cells?
    I get no other codes aside from a 420 one for my cheap aftermarket cat
  17. JohnPrius3005
    423
    235
    My understanding is its rarely "worth" just swapping out modules. Sometimes you can get kinda lucky, but often you don't really know what you are getting when you get replacements. And if the "new" ones are worse or better than the old ones that creates problems. You can get salvage HV bats from some junkyards. If the donor is actually low mileage and low age you might end up with a set of more or less matched modules (of course you have to verify compatibility with your old car). I've found (in LA) these salvage bats are about $1000 to $1500. It's still a lot of work, some of it fairly delicate (meaning you'll break and have to replace various things as you go) and obviously dangerous with around 200VDC. You will get a lot of different, strong opinions about all of this - "fully tested modules", etc. In the end there is no quick and easy fix which is likely to last more than a few weeks/months/days. You'll learn a lot in the process. These bats were really not designed to be "refurbed". Toyota would prefer you crush your car at 150,000 miles. And when dealing with the HV bat buy a new one from them. It can be an interesting, educational process dealing with trying to get a Prius with a bad HV bat back running. But to be sure it's not easy, or fast, although if you shop it can be cheap. Good luck amigo.
  18. rjparker
    rjparker Tu Humilde Sirviente
    11,097
    6,964
    Texas Hill Country
    If you like taking the battery apart every few weeks, over and over again, with the reliability of a twenty year Hyundai, go for it.
  19. mike_az_21
    26
    Arizona
    At least y’all say it how it is
    I had a chance to get an unused greentec upgraded battery for 700 bucks. But, the guy didn’t know where it came from, or had any paperwork for it.
    The Prius saga continues, I guess
  20. mike_az_21
    26
    Arizona
    Prius has been sold!
    It has definitely been a learning experience. But, imo - just get a newer Corolla & save yourself the headache of 3x the amount of systems & parts.
    These definitely do last! Almost 290k and the drivetrain was still strong.
    But, these insane fuel costs definitely fuel the mpg frenzy
    Brian1954 and JohnPrius3005 like this.
