P3030 code after cell replacement and battery reconditioning
Discussion in 'Gen 2 Prius Technical Discussion' started by AlaskaPrius2004, May 4, 2024.
  1. AlaskaPrius2004
    AlaskaPrius2004 New Member
    Girdwood, AK
    My 2005 Prius is throwing a P3030 code. About a year ago, I replaced a bad cell in the battery block and did a battery reconditioning using the Hybrid Automotive kit. Everything has been working well ever since.
    However, on my Dr. Prius App, I notice one blade voltage keeps going negative:
    Yesterday, after sitting for a few months while I was gone, the car threw a p3030 code when I tried to start it. I cleared the code and it immediately came back. The 12V was reading 12.3V, so I charged that for a bit, restarted the car, and haven't got a code since.
    I am guessing I have a loose lead or something like that on the battery harness? I was curious why having the 12V battery really topped off might prevent the car from throwing the code.
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,015
    NJ-USA
    You have an intermittent open circuit on one of the voltage sense circuits from the HV battery to the ecu. Could be a broken terminal at the battery stud, or corrosion at the orange ecu connector.
    AlaskaPrius2004 likes this.
  3. dolj
    dolj Senior Member
    8,648
    4,398
    Wellington, New Zealand
    ... or the No. 2 frame wire harness has corrosion wicking along the wire. It's also possible there is a break in one of the sensing wires in that same frame wire harness. Easy to do when you remove and reinstall it.
  4. AlaskaPrius2004
    Girdwood, AK
    I will reopen the HV and check all the leads/wires/harnesses. This Prius has lived on the coast its whole life and has had a lot of corrosion. In 2017, I replaced the entire battery wiring harness after finding it totally corroded.
  5. AlaskaPrius2004
    Girdwood, AK
    I finally got around to hunting for bad wires today. Here's what I found:
    So, looks like the diagnosis is we need a new ECU and harness. i replaced both of these components in 2018... 6 years for salvage parts isn't terrible. Anyone have a good source for these other than eBay?
  6. mr_guy_mann
    4,118
    2,015
    NJ-USA
    AFAIK, the harness is available from the dealer for a reasonable price.
    If you don't have a local wrecking yard, then ebay would be my choice.
    Brian1954 and AlaskaPrius2004 like this.
