P314A info code 828 Inverter Coolant Pump Speed Signal
Discussion in 'Gen 3 Prius Main Forum' started by UK Hybrid, Jan 19, 2019.
  1. UK Hybrid
    UK Hybrid Junior Member
    UK
    ----UK----
    Hi Guys I need help to sort this problem I already changed the Inverter, Inverter Pump, Power management ECU and IGCT No 3 Fuse. But there is no luck still getting same code P314A Inverter Cooling Pump Speed signal. After clearing the fault codes as soon I start the car all the warning lights goes off and radiator fan start running loudly.
    amos likes this.
    49,384
    is there movement in the fluid?
  3. Chuba
    Chuba Junior Member
    45
    Nigeria
    I have this the same issue. There is movement in the fluid
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    At this point, you almost need a Techstream or a scan tool with bi-directional capabilities. Time to bite the bullet...needs a diagnostic inspection. About the only thing you can do without the necessary equipment, is to check all your connectors at the ECM and at the coolant pump harness.
    3 thing that will cause this code:
    1 Bad coolant pump
    2 Bad ECU
    3 Bad or corroded wiring harness
    Good luck
  5. Chuba
    Chuba Junior Member
    45
    Nigeria
    Thanks for your response.
    I noticed that my inverter coolant pump is not runing very fast and I recently changed it.
  6. Bens
    Bens New Member
    2015 Prius: my car is having same issues as your car had. After an accident to left headlight and inverter, some wires got cut. Symptoms are: radiator fans blows fast and loud at all time; Check engine light is on; check hybrid system is on.
    Scan displays P314A. Mechanic says, I need a harness, and the hybird cooling system is not working. Price to fix is $3800-$7000. Please help. Any advices please...
  7. Grit
    Grit Senior Member
    6,141
    4,054
    Wilkes Land
    What did your insurance say to the price quote?
  8. Bens
    Bens New Member
    no insurance involvement. everything is out of pocket.
  9. Chuba
    Chuba Junior Member
    45
    Nigeria
    We are now in training season. Any time I enter water P314a code shows. I think it's a corroded wire but which wire pls?
  10. SteveSco
    SteveSco Junior Member
    uk
    Here is some info which may help.
    P314A-828
    Looks like a comprehensive way to get a bit deeper and trace the fault.
