P3190 and P3030
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blueprius2006, Jul 3, 2023.
  1. blueprius2006
    blueprius2006 Junior Member
    brooklyn, ny
    Hi Everyone,
    I am currently getting a P3190 (current fault) and P3030 (pending fault). The car turns on but can not be driven. (No 'Ready' mode, I tried putting it into Drive but only goes into Neutral (couldnt get back to Park until I shut it off...scary). Anyone have an idea of what the issue might be here. Many thanks in advance!
    AM
    52,433
  3. blueprius2006
    brooklyn, ny
    I thought I would update this. The shop said that oil had been overfilled, and it overflowed into intake manifold and throttle body. Throttle body and airflow sensor was ruined. $790 bill. They are fixing it now. Hopefully this solves the problems.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,098
    2,001
    NJ-USA
    Well, a dirty throttle body and MAF sensor certainly can result in P3190 (with "poor engine power" or a "crank - no start" condition). I consider cleaning both to be oft overlooked maintenance.
    However, it is "normal" to see oil puddled in the intake manifold on a Gen2 Prius. That has nothing to do with "overfilling the oil". (it results from the Atkinson cycle engine frequently shutting off and spinning without combustion). And that oil won't "ruin" either part.
    I am skeptical that there is/was any (permanent) fault with the TB or MAF. They can fail but it's pretty rare, and for both of them to go at the same time?
  5. bisco
    52,433
    i don't understand how that can lead to know ready mode
  6. blueprius2006
    brooklyn, ny
    This morning they also sent me a picture of a corroded pin on the hybrid battery module..
  7. blueprius2006
    brooklyn, ny
    here are the pictures they sent me ... is $200-300 a reasonable price to fix the corroded pins?
  8. blueprius2006
    brooklyn, ny
    Now they are saying that the Battery ECU is bad, and quoted me $450 for a replacement. Anyone have any ideas?
  9. bisco
    52,433
    a local mech might replace it with salvage for much less, idk.
    what i do know is that they are throwing parts and labor at it without following the service manual troubleshooting tree, and you should find another shoppe.
    blueprius2006 likes this.
  10. blueprius2006
    brooklyn, ny
    thank you ... im suspecting as much... hard to find a good shop!
  11. blueprius2006
    brooklyn, ny
    update: they said that the mass air flow detector did not have to be replaced. They did however replace the throttle body.
