P3190, Poor engine performance, no ready sign.
Discussion in 'Gen 2 Prius Main Forum' started by Priusprofit, Jul 26, 2018.
  1. Priusprofit
    Priusprofit Member
    96
    32
    Long island
    Looking for an explanation of what is causing these symptoms on my 2004 prius.
    I purchased this prius and it had codes for ignition coil and both o2 sensors. I replaced the ignition coil and the car began to run and drive like new, I then replaced both o2 sensors and the exhaust manifold (used manifold) which was leaking. The code for upstream o2 sensor went away(thank the lord, what a painful job) but the code for the downstream o2 sensor stayed. Then every 10 or so miles or at random startup, the prius will run very poorly like the flip of a switch, the red triangle and check engine light appears and the car will not go into ready mode. For 2 or 3 days I could just clear the p3190 code and the car would continue to run until code came back, but it now comes back instantly and the car is disabled.
    Today I will replace the downstream o2 sensor again in hopes that it could be a bad sensor causing this and then disconnect 12v battery before starting.
    If anyone has had any experience or has knowledge on this issue it is greatly appreciated
  2. Priusprofit
    Priusprofit Member
    96
    32
    Long island
  3. PriusCamper
    PriusCamper Senior Member
    13,080
    5,306
    Pacific Northwest, USA
    Just pulled this code from a friend's car that's about due for a tune up... So guess I'll do that first?
