P3191 No start
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by DavidDavid, Mar 15, 2023.
  1. DavidDavid
    DavidDavid Junior Member
    29
    I have 2012 Prius V with this code P3191 No start issue, I think it sounds like it is starting but it's not, I cleaned the EGR, intake manifold and MAF sensor, but I am sill getting the same issue, I am planning to replace the spark plugs, fuel injectors and the fuel pump. what do you think?
    52,762
    are you using tech stream? any sub codes to help narrow it down?
  3. Brian1954
    Brian1954 Senior Member
    2,652
    1,058
    South Central PA, USA
    Code P3191 does not have a sub code.
  4. Brian1954
    2,652
    1,058
    What is the milage?
    Did you have the no start P3191 before or after cleaning the EGR, intake manifold , and MAF sensor?
    Did you clean the throttle body?
    Also check for a vacuum hose that did not get connected.
  5. DavidDavid
    29
    I am using techstream, I think there was no subcodes.
  6. DavidDavid
    29
  7. Brian1954
    2,652
    1,058
    Check the spark plugs first and then the fuel pump.
    How many miles on the Prius?
  8. Tim Jones
    Tim Jones Senior Member
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    Do Not change all that without knowing what's going on.
    They could all be fine.
    Better investigate more.
    Did this just happen out of the blue?
  9. DavidDavid
    29
    I agree, that’s what I am going to do
  10. DavidDavid
    29
    The reason why I changed all those stuff, it’s because I had them in my place, so I thought I’ll try that and see, I have just bought this vehicle, a couple weeks ago.
  11. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    This is just the beginning of your gen 3 problems.............
  12. ttou68
    ttou68 Active Member
    351
    211
    The possible trouble areas for a P3190 are:
    Air induction system malfunction.
    Defective throttle body.
    Improper fuel pressure.
    Defective engine.
    Defective Mass Airflow (MAF) meter.
    Vehicle is out of fuel.
    Defective Engine Coolant Temperature (ECT) sensor.
    Defective crankshaft position sensor.
    Defective camshaft position sensor.
    Defective Engine Control Module (ECM).
  13. DavidDavid
    29
    Thank you, I checked most of these things, I will check or replace the rest
  14. DavidDavid
    29
    I worked on this vehicle this past weekend, changed the fuel pump with a used one, but that didn’t solve the problem, but when I checked the new used pump, i found out that it’s not running at all, the old one was working.
  15. DavidDavid
    29
    I took out the spark plugs and put Borescope inside and i have found out that there is water or coolant in every cylinder,
  16. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    DO NOT purchase a used Gen 3................. they get great mpg but when things go wrong there goes all of the fuel savings and the trouble that goes with this HG problem... plus the possible oil consumption, brake system and big (traction) battery failure in the back and the most likely inverter failure a long way from home. Could easily cost $6000 or more if you can't do the repairs yourself.
    I'm still driving toys everyday... but they are ICE.
    DavidDavid likes this.
  17. DavidDavid
    29
    I agree, if you are DIYer or know a good cheap mechanic, don't buy a used hybrid vehicle,
    Tim Jones likes this.
  18. Tim Jones
    1,760
    567
    SE Texas
    2011 Nissan LEAF
    I knew a couple from Starbucks..... I told them the car was going to blow the head gasket.... they just skoffed at my comment. and told me it's the best car they have ever had... thought i was totally wrong....even told them to trade it off or get online and read about it.... then a couple of months later I seen them driving a toy SUV... asked what happened to prius.... blown head gasket, got hot ruined the engine.... and this happened on I10 between San Antone and Houston in the summer.........
    #18 Tim Jones, Mar 20, 2023
