Pack lifetime, NiMH vs. Lithium?
Discussion in 'Gen 4 Prius Technical Discussion' started by pasadena_commut, May 9, 2026.
  1. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    Have the OEM lithium packs been around long enough to compare pack lifetime against the OEM NiMH ones? This would be the mean (or median) time until pack failure for the two types. (Other differences may be significant but are not the point of this thread.)
    I believe the 4th generation is the first where this comparison is possible. Our car is a gen2, and there was no OEM lithium option. The aftermarket lithium option was not as long lived as the OEM NiMH, but neither were most of the aftermarket NiMH, so that isn't much of a predictor for the OEM lithium.
  2. Rmay635703
    Rmay635703 Senior Member
    2,702
    1,729
    Somewhere in Wisconsin
    2013 Chevy Volt
    Gen 3 Euro 3 row models
    2016+ Eco models
    so 10+ years for some
    52,855
    degradation of lithium in Bev's has some good long term testing. they have shown very little over long periods of time and mileage.
    2012 plug in prius has lithium and very few complaints
    Rmay635703 likes this.
  4. pasadena_commut
    3,065
    951
    Southern California
    Very implementation dependent. Consider the first generation Leaf. Those packs were not fluid cooled and they did not hold up well at all. The Gen4 Prius can swap NiMH (for cold climates) and Lithium (elsewhere), so I'm assuming that both are cooled the same way. Air or fluid, presumably air. Air cooling is adequate for NiMH (based on historical pack lifetimes), it might not be for Lithium. It might be that NiMH packs would last longer if they were fluid cooled. Hard to do the experiment as neither the modules nor the pack are designed for it (at least for Gen2, Gen3, and I assume Gen4, since those modules fit the earlier packs.)
  5. bisco
    52,855
    the pip is air cooled lithium, really lasting a long time and high miles so far.
    Bev's probably require liquid cooling
    PHEVisthefuture likes this.
  6. pasadena_commut
    3,065
    951
    Southern California
    BEV packs can certainly move more total current than one on a Prius, and have a larger volume. There is a point where air cooling just cannot get heat out of a box fast enough so fluid cooling is used. Although, in the majority of these instances the heat is eventually carried off by air passing over a radiator. I'm guessing that both a BEV and a PIP have about the same maximum current/maximum short term heat generation per cell, which is set by the chemistry and packaging. The Tesla packs are serial/parallel, with M cells in parallel organized into N sets in series. The Prius Lithium packs are said to be purely serial. The volume of the packs may be the most important factor. Prius packs are small, BEV packs are large. It may also be that the cells in a BEV are packed tighter together or the geometry is such that it reduces the available surface area, and so makes the heat capacity of the coolant more critical.
  7. Prius23years
    Prius23years Junior Member
    Derby England
    2021 Prius PHV
    Business Ed. Plus
    I think that for Gen 1 to Gen 4 all HV batteries were air cooled, Including the Gen 4 PHEV (Prime designation in the US) that had a 8.8kWh lithium battery. For Gen 5 I know that the PHEV (Prime in US) which has a 13.6kWh lithium battery uses refrigerant coolant. I don't know what method of cooling the Gen 5 non plug-in standard hybrid uses.
  8. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    My Gen 4 Prime has the 8.8kWh lithium battery and so far, I can still get 25 miles if I keep the speed under 55MPH, and no signs of battery degradation that's severe (my Volt would park with 10 miles and show 0 when I got back in, on either a hot or cold day), so at 106k miles, I think the pack will reach the 10 years / 150k Toyota has likely engineered these for, which is very good.
    At that point, if I need to cough up $10k for Greentec Auto to replace the battery, so be it - probably put it on a 0% for 12 months credit card and just consider that the cost of ownership. Not excited about having to tow it to Greentec when that happens, but I heard they are good folks to deal with. Maybe I'll budget for the cost of a U-Haul and U-Haul car trailer too, as tow people are expensive!
  9. bisco
    52,855
    I think it will last much longer, unless you're very unfortunate
