Paint Bubble on Door Seam?
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by thefranchise713, Jul 11, 2019.
  1. thefranchise713
    thefranchise713 Junior Member
    75
    52
    Buffalo, NY
    2018 Prius Prime
    Found a bubble on the inside of my driver's door. Anything to worry about?
    If I press on it, it does seem to have some rubbery give to it. I don't remember seeing this before tonight.
    49,399
    nah, i think you're fine. don't squeeze it
    will the engineer likes this.
  3. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    I would not worry. Leave it alone.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Don’t poke the carbuncle;).
    It can only get worse(y).
  5. thefranchise713
    75
    52
    Buffalo, NY
    2018 Prius Prime
    You folks rock.
    What am I looking at exactly? It doesn't seem to be a paint run. My concern is that there might be corrosion/rust starting under the seam.
  6. bisco
    49,399
    poly not until you puncture it. but if you can't stand not knowing, be prepared to repair it properly after removing the bubble. (whatever that entails, maybe ask the dealer body shoppe)
  7. thefranchise713
    75
    52
    Buffalo, NY
    2018 Prius Prime
    Ran up to my selling dealer for grins. They seem to believe it's just a rubber piece that wasn't molded properly or had some kind of defect. In their eyes, happy to warranty repair it, but probably counterproductive as we'd have to destroy a good seal to do it. So, going to leave it. It's not corrosion, so no harm, no foul.
    Panic averted--thanks for replies.
  8. Mendel Leisk
    38,661
    Is there anywhere in the vicinity where caulking is used? Maybe something dripped and got painted over?
  9. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    To me it looks like the bubble is along a seam, so maybe a panel defect:whistle:?
