Paint discoloration
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by SadRobot, Apr 29, 2026.
  1. SadRobot
    SadRobot New Member
    Los Angeles
    2025 Prius
    Anyone know what this paint discoloration is? It does not come off with cleaning products and the surface is smooth so it has to be under the paint. Could it be rust forming under there? Any idea how to remove?
    I've only had this Prius since June of last year.
    52,863
    should be under warranty?
  3. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    If you're willing to DIY, I'd give it a pass with a clay bar. You'll need to wax the spot after. Which body panel is this on? The hood is aluminum so it won't rust.
  4. SadRobot
    SadRobot New Member
    Los Angeles
    2025 Prius
    It's on the hood.
  5. dicknose
    dicknose New Member
    Toronto
    2024 Prius Prime
    XSE Premium
    Well then at least you can be re-assured its not rust. Probably a bug that went splat and its gooey remains baked in the sun. This stuff can get baked into the clear coat and a pass with a clay bar should get it out. Recommend reading into how to properly use the clay bar.
