Painted interior A Pillar plastic panel?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by runnerstreet, May 25, 2015.
  1. runnerstreet
    runnerstreet Junior Member
    Baltimore
    Has anyone ever sanded the felt like surface on the interior A Pillar plastic panel and spay painted it?
    Thinking of doing this cause I don't like the tan panel with black dash.
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    It’s flocked so use solvent like acetone to clean it. What plastic is the part made out of? It should be marked on the part itself. After you know the type of plastic you know what to use to clean it and paint it. Probably only minimal sanding is required. Here is topic about removing that part removing A pillar cover | PriusChat
