Painting stock hubcaps, sort of...
Discussion in 'Gen 3 Prius Accessories and Modifications' started by TheFenux, Jul 21, 2015.
  1. TheFenux
    TheFenux Junior Member
    31
    Oklahoma City, OK
    I'm getting ready to paint my stock hubcaps because I can't find anything I like aftermarket. It'll be all black, including lug nuts, when I'm done. However...
    I want to get rid of the Toyota logo on them. When I pull them off, I'm left with an empty space with mounting holes. Any suggestions on what to fill it with to sand it flat? Or possibly even something else that will fit there?
  2. Priusguy78213
    Priusguy78213 Junior Member
    94
    30
    San Antonio, TX
    Just pull off those crappy covers. There's some nice looking wheels behind the plastic. That way you don't have to worry about trying to fill in the space on the snap on cover. Looks like they have all sorts of road rash anyway. Just ditch them.
    HelloHybrid likes this.
  3. TheFenux
    31
    Oklahoma City, OK
    I was going to sand out the road rash first anyway. The brakes and whatever is in the middle of the tire looked funny to me when I pulled them off to consider that.
    So far the best suggestion I've gotten is a fiberglass resin to do the fill.
    SM-N910T ?
  4. DoubleDAZ
    DoubleDAZ Senior Member
    1,189
    308
    Peoria AZ (Phoenix)
    Lowe's and Home Depot, as well as Michael's, all have pourable plastic/fiberglass resins that would probably do the job. However, I'd be concerned that the filler might not bond to the hubcap properly and eventually come loose, so make sure you get some through those holes to help the filler stay put.
    I thought plasti dip would be a better solution, but I was viewing a video on how to apply it on some wheels and noted that the technician mentioned it would probably last a year or so. He also noted that you need to be careful not to pull on the edges, etc., while cleaning because it would peel right off. That leads me to believe it is designed to be a "temporary" covering until the wheels need to be rotated, etc., and then it would have to be reapplied. He also covered the lug nuts, so there was no way it was going to last when the tires needed to be rotated, repaired, etc.
    Obviously you plan to sand the hubcaps before painting so the paint will adhere better, but I'd still be concerned about how well it will adhere when the hubcaps get flexed when removed and put back on. At a minimum, I believe the paint will come off the lug nuts when you rotate the tires, so I'd suggest buying a set of aftermarket black lug nuts.
    As an aside, a lot of people pay a lot of money for aftermarket alloy wheels to get rid of stock wheels and hubcaps. I was going to do the same when the OEM tires need to be replaced and was in the same camp as you seem to be about leaving the hubcaps on to cover the brake rotor and calipers. I was more concerned though about all the black (wheels and tires) against the Blizzard Pearl than the rotors and calipers. However, I recently removed the hubcaps before my last service appointment and added some Toyota center caps. Surprisingly, I like the look a lot more than I though I would and have decided to leave the hubcaps off. I think I'd still prefer color-coordinated wheels, but after watching that video, I've given up on the idea of plasti dipping because I do rotate my tires and it looked like I'd have to dip them each time.
    Good luck with whatever you decide to do and be sure to post a photo.
  5. TheFenux
    31
    Oklahoma City, OK
    I saw some of the same stuff on Plasti-Dip. That's why I chose Krylon Fusion. It shouldn't go anywhere.
    I was also going to go with the aftermarket black lug nuts. I wasn't going to paint them.
    I did find some alloy wheels that looked good, but $90 each was too steep for me right now.
    As for the center cap, I didn't know that was an option. Where did you pick those up? And is it possible to find plain ones? I don't want logos of ANY kind on the wheels.
    SM-N910T ?
  6. DoubleDAZ
    1,189
    308
    Peoria AZ (Phoenix)
    Some folks get electrical inserts from Home Depot and paint them. They get the closest size and bend the tabs to keep them snug. I bought Toyota ones from Amazon, but eBay might have some plain ones. If not, you could probably fill in the Toyota ones and paint them black.
  7. nsb
    nsb Junior Member
    33
    Hawaii
    Thanks for taking this on, i'm in the same dilemma. I just recently lost a hubcap driving, so I pulled all the hubcaps off until I figured out what to do. I wasnt really into blizzard pearl with all black rims/tires but the look is sort of growing on me, but the wife thinks it looks "ghetto" and I kind of agree, and kind of disagree. I think if I had caps on it would look a little more completed but not sure. I like the idea of the prius looking different then 99% of the grandmas driving theirs, but I'm not willing to drop 1-2k+ on new rims. Painting the hubcaps black got me curious, maybe it would look a bit more completed. Has anyone done that on a Gen 3? Maybe a photoshop of it? I'd personally leave the toyota logo on the caps and just spray em black....seems a lot easier... anyway, hope it works out for you, maybe I'll do the same project.
  8. TheFenux
    31
    Oklahoma City, OK
    I'll be picking up some fiberglass filler for them tonight.
    I MAY be doing a dark crimson red on the sections that don't go toward the center. It's an all black gen 3, but I'm slowly doing some gunmetal vinyl around the windows and inside. I might also be hitting the hatchback in a couple places with it too.
    SM-N910T ?
  9. HelloHybrid
    HelloHybrid Senior Member
    482
    1,483
    Have you considered just painting the stock wheels a silver-ish color with plastidip in case you don't like how it turns out? It'll be less than $50 to complete the project after purchasing center caps, paint, and clear coat... which is still cheaper than buying a replacement hubcap.
  10. nsb
    nsb Junior Member
    33
    Hawaii
    Yeah that's another option that I was thinking about as well, just a bigger project. has anyone on here done it? Possibly swapping rims with an owner that has silver stock rims...but in hawaii a lot less of a pool to choose from.... I think if the wife didn't really care I'd just get black center caps and maybe black lugs and be done with it...we'll see how it goes tho, thanks for the suggestion.
  11. nsb
    nsb Junior Member
    33
    Hawaii
    Any update on painting the caps?
  12. TheFenux
    31
    Oklahoma City, OK
    I gave up on filling the centers for now. I have some ideas for down the road.
    The clear coat messed up my prototype, so I think I need to so it over. Pretty sure it was my fault. Unfortunately the pic from before the clear coat was lost. But so far, I'm happy with how it's turning out.
  13. nsb
    nsb Junior Member
    33
    Hawaii
    cool, post pics when your'e done!
  14. TheFenux
    31
    Oklahoma City, OK
    Here's the, more or less, finished product. It's all done with Krylon SUPERMAXX. I may still do an enamel clear coat, but I want to see how this holds up first. And my lack of experience with a spray can shows on a close up. If they don't hold up, it gives me an excuse to redo them right.
    They'll also look better after I treat the tires and replace the lug nuts with black ones.
    They're also a few other touches I plan to do that will make the red match.
Loading...
