panasonic ev battery specifications
Discussion in 'Gen 2 Prius Main Forum' started by jen_wwc, Jun 22, 2004.
  1. jen_wwc
    jen_wwc New Member
    I am currently developing a laboratory for Walla Walla College that will study the interaction between fuel cells and batteries. I am interested in Panasonic EV's NiMH Prismatic Module because it is already being used in the Prius. In order to use these batteries as an example, I need to model them. This requires some information on their performance specifications. The information I need is: terminal voltage, internal resistance, and efficiency as a function of state of charge and temperature as well as state of charge as a function of temperature. Also, what charge configuration (constant voltage, constant current, or tapered) is recommended if any?
    I would appreciate any leads that would help me obtain this information.
    Thanks!
  2. CarlK
    CarlK New Member
    30
    North Carolina
    If you don't get any information here, I'd suggest trying a Yahoo auto group called "Prius_Technical_Stuff".
    Carl
  3. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
  4. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    I know Wayne Brown had all of this info, he may hang out on the technical YG.
  5. kenkneeb
    kenkneeb Member
    120
    So. Central, Pacific SouthWest Oregon
    Hi Ken:
    Do you know whether it is possibe to install/swap out the current Panasonic NiMh batteries in my new '05 Prius with a higher battery with a higher than the present 6.5Ah batteries without any modification to the electronics or software?
    Please Advise
  6. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    Hi Ken,
    I don't know.
    Why don't you ask master Wayne Brown about it?
    http://privatenrg.com/#2004Ah%20work
    Ken@Japan
  7. kenkneeb
    kenkneeb Member
    120
    Thanks Ken, I'll email Wayne
  8. kenkneeb
    kenkneeb Member
    120
    Ken: I went the to very incredible site in your post, however I could not find an email address or website for the Hon. Mr. Wayne Brown.
    I also did a search on PriusChat and it came up with no hits.
    Thanks, KenYOregon
  9. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
  10. kenkneeb
    kenkneeb Member
    120
    Oye! What code breaks thru yonder scanner window!!!
    Perhaps I'll start with the ScanGauge. Any other place to get a good deal on a ScanGauge than the Mfgr's website?
  11. ken1784
    2,940
    1,365
    67
    Yokohama, JAPAN
    As Carl suggested on the #2 post of this thread, please visit the following Yahoo Group...
    http://autos.groups.yahoo.com/group/Prius_Technical_Stuff/
    The target poster is "mwbueno" or Wayne Brown.
    Ken@Japan
  12. kenkneeb
    kenkneeb Member
    120
    Thank You Ken and Carl.
    I will follow the thread you've both mentioned.
    Regard,
    KenYOregon
  13. McShemp
    McShemp New Member
    371
    SA, TX
    The system is designed around the battery. If you change it, the control strategy won't work correctly; i.e., modifications you can't perform will be needed.
