Panic Button on key fob
Discussion in 'Gen 2 Prius Technical Discussion' started by marjam, Jun 28, 2006.
  1. marjam
    marjam Member
    220
    Silver Spring, MD
    Does anyone know if there is a thread or information about the panic button on the key fob and if it can be disabled? It goes off when the key is in my pocket and I am getting into the car. (all right, I could lose a little weight!) If I am holding it in my hand and taking out groceries I hit it, etc. I don't want to disable the system, just the panic button. Any ideas?
  2. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I believe that is an option your dealer will have to disable with the scantool.
  3. Tideland Prius
    16,074
    hmm.. but the panic button has to be held. It doesn't go on if you press it. You'd have to hold it for a second or two.
    But yeah, it should be dealer customisable.
  4. marjam
    marjam Member
    220
    Silver Spring, MD
    <div class='quotetop'>QUOTE(theforce @ Jun 28 2006, 03:22 PM) [snapback]278173[/snapback]</div>
    Mine must be extra sensitive. It goes off if you brush it!
    Thanks for the advice.
  5. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    <div class='quotetop'>QUOTE(marjam @ Jun 29 2006, 08:04 AM) [snapback]278514[/snapback]</div>
    I snagged this file from the Prius-2G Yahoo! group. It was from efusco. The alarm is the 3rd item under the wireless configurable options. It might help to take a printout of this to the dealer to illustrate what you want to the service writer.
    - Tom
  6. marjam
    marjam Member
    220
    Silver Spring, MD
    <div class='quotetop'>QUOTE(Tom_06 @ Jun 29 2006, 09:05 AM) [snapback]278526[/snapback]</div>
    Thanks!
    You guys are wonderful
    marjam
