Parallel battery question
Discussion in 'Gen 2 Prius Technical Discussion' started by Jaron Lindow, Jul 4, 2018.
  1. Jaron Lindow
    Jaron Lindow Junior Member
    24
    St George, UT, USA
    Has anyone tried running parallel battery modules? Not parallel packs, but individual modules twinned with other modules.
    Assuming the supplemental modules can be cooled, compressed, secured, and each supplemental module is wired directly to just one original module, it seems like this would increase capacity and reduce resistance.
    This must be a bad idea or I think I'd have found an example of it being done. What am I missing?
  2. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    I haven't heard of anyone doing that. It sounds theoretically possible, but would be a huge job, plus expense, that would never pay for itself.
  3. Jaron Lindow
    24
    St George, UT, USA
    If someone had an extra battery pack lying around, it would mainly just be a matter of wiring. What's the main downside? Would the weaker module of the pair kill the good module? Or explode?
    52,858
    wouldn't you need to rework the control software? that is the hard part. if it was easy, it would have been done, unless you've stumbled onto an easter egg.
    David3, padroo and Raytheeagle like this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    You got some of those lying around still from Easter :p?
    padroo and bisco like this.
  6. fuzzy1
    10,710
    Electrically, it would be no different than simply paralleling two whole packs. But mechanically, it would be more difficult.
    jerrymildred likes this.
  7. bisco
    52,858
    Raytheeagle likes this.
  8. Jaron Lindow
    24
    St George, UT, USA
  9. bisco
    52,858
    eureka! that's it!(y)
  10. Jaron Lindow
    24
    St George, UT, USA
    The voltage sensors would need to be split between the two packs as well.
    Bruce Berquist likes this.
  11. MickyMatter
    MickyMatter Active Member
    260
    168
    Germany
    I was wrong, deleted.
  12. bisco
    52,858
  13. jerrymildred
    11,517
    14,167
    Tampa, FL
    You'd give up storage and add weight. And your gas mileage would maybe go up by 1 or 2 mpg at most assuming you would operate it like a normal hybrid.
    Well, I did think of one sort-of positive. With more cells, the cells would cycle less and should last longer.
    But it would be interesting as an experiment.
  14. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    I think that can be achieved. But my concerns would be that the arranged packs would occupy more space. And what exactly are you trying to achieve?
    I do know laptops, and some stuffs, have got parallel/series arrangement in their circuitries.
  15. Jaron Lindow
    24
    St George, UT, USA
    It's wasted space presently. Just an empty plastic bin sitting above the spare tire. And the curb weight increase would only be 3%.
    The objective would be to get a setup with better charge/discharge/capacity (i.e. performs more like new) using old modules, which would be significantly cheaper than a brand new battery pack.
  16. Raytheeagle
    11,269
    15,528
    2019 Prius Prime
    Using old modules runs the risk of failing modules and then rebuilding again and again and again.
    You would also have 2x the problem as normal owners would have;).
    Good luck with your project(y).
    jerrymildred and bisco like this.
  17. padroo
    padroo Senior Member
    2,763
    2,253
    I would think software issues too.
    Without the ability to charge the larger pack probably not much gain.
    Has anyone ever added charging capabilities to the existing battery pack?
  18. Dxta
    Dxta Senior Member
    1,945
    770
    Lagos
    ...and if you want a success to em, I think you got to add a separate BMS to the pack, to care for the added one.
  19. bisco
    52,858
    no one has ever added a plug to the stock pack, it wouldn't be worth the cost or effort.
    people have added batteries and a plug though, back in the day before the plug in came out. and they were geniuses.
    now, it's just pointless.
  20. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    Toyota already thought of that. Then realized how much power it would take to charge double battery load and how much weight it would add.
    G2 degined mgs would not able to charge that load without killing car power and that forced them to the drawing board and out came the g3 mgs.
    jerrymildred and Raytheeagle like this.
